If this is right, he is confirming what I told you guys about the vertex 3 not being able to reach is full performance on the marvell because it's only using 1 lane.
I can't find the tRRD in the BIOS, is it there at least ?
just love this board really worth the price!
Got my RE3 back from RMA, time to rejoin the fun :) comparo with the G1 sniper in the making...
ok for some reason mem cant run 2:6 divider, getting "uncorrectible hardware error". but 2:8 works fine :( with default timings.
can this be mem problem ????
Okay guys got it now, thanks a lot.
The time when i was full on spi32M is far away apparently, shame on me...
Ack, not sure how i typo'd 6gb/sec TWICE in the same post talking about 5gb/sec.
One gigabit is 1 billion bits.
So that's 5,000,000,000 divided by 8 to find the number of bytes/sec. = 625,000,000 bytes per second. there are 1024 bytes per kilobyte, then another 1024 per megabyte, so that equals 596MB/sec at 5Gbit.
Which illustrates what I was really trying to say about how 640mb/sec is above 5Gbit...
hey guys, is i7 965 EE 4.0g's @1.35v, QPI/v@ 1.3875..safe for 24/7..?..
I have had to remove AiSuite, althought before I used the fans controls when it work.
Turbo V EVO works EXCEPT! The CPU multiplier setting. It won't go lower than 25, but when at 200 BClk, you NEED lower.
So if one of you guys solved the BIOS and one of the new Turbo V's please let me know.
R
[edit]
FYI: TurboV EVO 1.02.28 doesn't cut it.
i have tried to work out the current issue of the i7 970 (GT) that is
affecting my system and many other people here and im almost 100% done.:p:
after tweaking around with timing tables 1st and 2nd, i found that simply
increasing the "Read to Pre" highlighted in red, removed my cap of 56/57GFlops in Linx when testing for all memory.
on auto anything below 12 was capping my system to low Gflops.
good luck...
now after you solve your problems with low Gflops, you can help me narrow
out why my system goes back to low Gflops after the 15/16th LinX Pass.:shrug:
i dont want to say NB Temp as it reaches 61C/63C after the 12/15th pass
http://i121.photobucket.com/albums/o...th_4240Mhz.jpg
>DRAM Timing Control--------------------------
CAS# Latency 9 [8]
RAS# to CAS# Delay 9 [9]
RAS# PRE Time 9 [8]
RAS# ACT Time 30 [30]
RAS# to RAS# Delay 7 [AUTO]
REF Cycle Time 132 [132]
WRITE Recovery Time 15 [15]
READ to PRE Time 14 [14]
FOUR ACT WIN Time 26 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
donmarkoni, can you share your actual bios settings ? :D :help:
Thanks.
Hello guys,
I have bought myself a licensed version of "StorageCraft ShadowProtect 4 Desktop Edition" as I read on the internet you can use this software to
backup a non RAID install and restore your backup to a RAID setup using the "StorageCraft ShadowProtect Recovery Environment CD" option HIR in
the software without having to reinstall windows.
The question I want to ask is what is the best RAID stripe size to use with two Crucial RealSSD C300 256GB drives in RAID0 and will windows 7 automatically
set the stripe size to the best for me when I create my drive partitions using the windows 7 DVD or would I have to set the stripe size manually?
If I have to set the stripe size manually, what is the best method of doing this and does the stripe size have to be set before createing any drive partitions or after?
Thanks for responding.
wow you are really lazy.
http://lmgtfy.com/?q=crucial+c300+stripe+size
the FIRST result.
http://forum.crucial.com/t5/Solid-St...300/td-p/38326
No problem. :up: Sorry for late reply. Here you go:
4700/4000/3600/2000
Code:Target CPU Frequency 4686MHz
Target DRAM Frequency 1992MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Enabled] ** Gone since BIOS 0003/1301
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
2D Performance Booster [Disabled]
CPU Ratio Setting [33.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
MPS and ACPI MADT ordering [Modern]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Performance/Watt select [Power]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Auto]
C1 Auto Demotion [Enabled]
C3 Auto Demotion [Enabled]
BCLK Frequency [142]
PCIE Frequency [100]
DRAM Frequency [1992]
UCLK Frequency [3986]
QPI Link Data Rate [6833]
Memory Recheck [Disabled] ** BIOS 1301
Memory Configuration Protect [Disabled]
CAS# Latency 7 [7]
RAS# to CAS# Delay 7 [7]
RAS# PRE Time 7 [7]
RAS# ACT Time 20 [20]
RAS# to RAS# Delay 3 [3]
REF Cycle Time 60 [60]
WRITE Recovery Time 9 [9]
READ to PRE Time 5 [5]
FOUR ACT WIN Time 20 [20]
Timing Mode 1N [1N]
Round Trip Latency on CHA 53 [53]
Round Trip Latency on CHB 55 [55]
Round Trip Latency on CHC 57 [57]
tRL Channel A [Auto] ** BIOS 0003
tRL Channel B [Auto] ** BIOS 0003
tRL Channel C [Auto] ** BIOS 0003
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 19 [Auto]
READ To WRITE Delay(DD) 8 [Auto]
READ To WRITE Delay(DR) 8 [Auto]
READ To WRITE Delay(SR) 8 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Disabled]
CPU PWM Frequency [Auto]
Extreme OV [Enabled]*
Extreme OC [Auto]
CPU Voltage 1.468 [1.47500]
CPU PLL Voltage 1.349 [1.35150]
QPI/DRAM Core Voltage 1.376 [1.38750]
DRAM Bus Voltage 1.746 [1.74900]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [+0mV]
DRAM CTRL REF Voltage on CHA [+0mV]
DRAM DATA REF Voltage on CHB [+0mV]
DRAM CTRL REF Voltage on CHB [+0mV]
DRAM DATA REF Voltage on CHC [+0mV]
DRAM CTRL REF Voltage on CHC [+0mV]
IOH Voltage 1.151 [1.15275]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
*QPI Voltage OCP [Enabled]
*IOH Voltage OCP [Enabled]
*DRAM Voltage OCP [Enabled]
*QPI PWM Frequency [Auto]
*IOH PWM Frequency [Auto]
*DRAM PWM Frequency [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
***on-board jumper dependant
donmarkoni :clap: :bows: :bows:
Thanks.
Here it is 2-60-8-4 :) (tRRD-tRFC-tWR-tRTP) set in BIOS, passed MemTest4.20
BTW, I was always wondering why CPU Tweaker shows wrong tWR. Also, tRTP is 4, not 2, as both programs show. Or is it?
http://img717.imageshack.us/img717/1...000777201t.jpg
I've noticed the same thing. tWR always shows as 12... I have not found any way to tell if the BIOS is not setting correctly, or if CPU-T does not display it correctly.
I've also noticed that tRTP always seems to be = tRRD in CPU-T. Also not sure how to determine if this is correct or not.
I think the only way we can tell is by raw bandwidth.
This troubles me from SiSanda (latest version)
Can others verify if they see same on other channels?
Thx
