Four... Four PB and Jam samiches... Ha ha ha haaaa
http://img822.imageshack.us/img822/5898/dsc03460w.jpg
http://img267.imageshack.us/img267/9000/dsc03461z.jpg
http://img215.imageshack.us/img215/2549/dsc03464zz.jpg
http://img546.imageshack.us/img546/673/dsc03466u.jpg
http://img196.imageshack.us/img196/1772/dsc03456l.jpg
http://img545.imageshack.us/img545/8199/dsc03470f.jpg
http://img820.imageshack.us/img820/86/dsc03469k.jpg
http://img826.imageshack.us/img826/7909/dsc03467q.jpg
http://img813.imageshack.us/img813/9954/dsc03468t.jpg
gonzalo 88
Good, clean looks system.
Who is manufacturer of this tubes?
I'm thinking folks need to re-read the rules in the first post again.
rear fan is still missing.... :rolleyes:
http://www.abload.de/img/2clu3s.jpg
http://www.abload.de/img/1fwjvn.jpg
Fear where did you get the white PSU connectors? I've been looking everywhere for them to go with my white/red single sleeved cables but cant find them anywhere?
650D, XSPC bay res/pump combo, EK HF block, EK 280 rad (passive), tygon and some fittings. Cooling an i7 920 @ 4ghz, 2x580's on air.
http://iforce.co.nz/i/wb43dorg.hgc.jpg
http://iforce.co.nz/i/upypm5z5.cbe.jpg
http://iforce.co.nz/i/4j0t0sgp.lzi.jpg
Hey Everyone, Iv been lurking this thread for months now, i love all the amazing rigs and positive feedback here and i feel its my turn to contribute. Sorry the Pics are of poor quality.
http://i423.photobucket.com/albums/p...124_155157.jpg
http://i423.photobucket.com/albums/p...124_155320.jpg
http://i423.photobucket.com/albums/p...124_155349.jpg
HAF 932
Gigabyte UDA7
AMD 1100T@ 4.2Ghz
16GB Mushkin enhanced redline
Gainward GTX580 Phantom 3GB
HTO Claro Plus
WD Raptor
Water temps (idle 72F -Load 96F)
Corsair AX1200W sleeved cables:
http://img84.imageshack.us/img84/523/dsc5461q.jpg
http://i43.tinypic.com/2a69oo4.jpg
http://i43.tinypic.com/dfdtaf.jpg
http://i42.tinypic.com/29c9u7l.jpg
http://i43.tinypic.com/amqdxs.jpg
After having my radiator delayed by customs for over a week, finally got it all together. Will spend the night overclocking and tweaking :D
What tubing ohms?
Finish
http://img38.imageshack.us/img38/6425/dsc03472g.th.jpghttp://img46.imageshack.us/img46/1166/dsc03473k.th.jpghttp://img33.imageshack.us/img33/4421/dsc03477ps.th.jpg
http://img42.imageshack.us/img42/81/dsc03487sd.th.jpghttp://img198.imageshack.us/img198/8...03490gc.th.jpghttp://img826.imageshack.us/img826/5...c03514o.th.jpg
http://img830.imageshack.us/img830/8...c03491g.th.jpghttp://img685.imageshack.us/img685/6...c03492y.th.jpghttp://img41.imageshack.us/img41/9021/dsc03493xq.th.jpg
http://img28.imageshack.us/img28/6638/dsc03495q.th.jpghttp://img848.imageshack.us/img848/8...c03501x.th.jpghttp://img600.imageshack.us/img600/2...c03506p.th.jpg
http://img96.imageshack.us/img96/5669/dsc03507z.th.jpghttp://img256.imageshack.us/img256/8...c03512g.th.jpghttp://img163.imageshack.us/img163/7...c03513o.th.jpg
http://img823.imageshack.us/img823/2...c03515h.th.jpghttp://img689.imageshack.us/img689/1...03548lt.th.jpghttp://img27.imageshack.us/img27/9206/dsc03560hy.th.jpg
Worklog (in Portuguese) here: http://adrenaline.uol.com.br/forum/g...nsion-cyo.html
nice rig ohms
@ mycoolcar
Do you have any vents except the ones on GPU at that rad? Nice build BTW. :up:
Maybe just hide that LED strip a bit more if possible.
@fr0wn3r
I have the front stock 200mm bringing air in, rear 120mm bringing air in too, so positive pressure which flows out through the radiator. If you place your hand above the rad outside the case, you can feel the heat and airflow coming out, so it does work. The LED strip is a bit in your face when the side panel is off, but when its on you just see the white glow from inside the case, which is much nicer.
same old same old
Attachment 124023
Attachment 124024
Attachment 124025
