I still see no compelling reason to update from 0308 to 0401.
Thanks ill check out the links, i have been out of the loop for a while, even got the x38 cause of the rocketraid 3520 and 4 wd640gb not cause crossfire
Yap, exacly what im asking, i would like to know the final resistance before i assemble everything, dont have the space to test it out of the case.
With loadline, what kind of a vdoop do you get?
For loadline enabled I get this on 2 different boards
qx6700 at 3.8-3.6Ghz on Maximus around .01
qx9650 at 4.5Ghz on Maximus SE around .02 to .025, which is a little more then I like normally, however since the 45nm is less tolerant of voltage I don't mind a little droop to prevent overshoot returning from load to idle.
Im currently priming at 3200 just to find a nice stable 24/7 clock with low volts . With loadline enabled and vcore set to 1.25v in bios , cpu-z is showing 1.232v loaded , so thats pretty decent . Next time Im running at max overclock I will check again though I think it drops a little more at higher voltages.
:up:
thanks guys, i might not even bother with the mod then, on the ga p35-ds3p i got now i get 1.248 on idle and 1.216 on small fft load, so at least asus doesnt seem worse than that if not better at least, thaught it had a bigger drop than that.
Reaching out for help.
I tried some of the templates on the first post, but I can't get mine to OC at all. It kept saying OC failed (something like that). Please forgive me, as I am still learning all this. :D
I made all the changes, but when I go to the CPU advanced Configuration, my CPU information never changes. It always shows 2.4GHz.
Can anyone help me? Anyone with similiar hardware can post there settings? Thanks.
-hdpc
Hehe, thanks. But there's a lot more to it than just PL and pull-ins. It is my 24/7, and I stole most of what I know from Zucker and Grnfinger. A really high FSB in the 333 strap for 8:6 seems like the sweet spot with my RAM (and maybe the board???). I run at PL7 with no pull-ins. Pulling in phases 4 and 5 can POST, but not OS. Of course, the Ballistix are good even though it's not on the Crucial QVL. Some people have problems, but I've had nothing but success.
@ Millyons, sorry I don't know the answer to your question about the voltage. I really hope you read that article, though. It might convince you that the Rampage BIOS is worth flashing to. Once you have a USB drive dedicated to flashing BIOS, it becomes infinitely simple to flash to a new RF BIOS or flash back to MF BIOS. Honestly, it's almost as easy as EZFlash! Oh, and by the way, my sister lives in Beograde. She teaches English at a uni there; not sure which one. :p:
Hmm...
Well I can't run that FSB on my quad. I've got 421 FSB with 561 RAM
I'm on the 400 strap tRD 6 and tRFC 60 all pullins disabled with 8GB. I'm still pretty happy with my bandwidth, but yours is awesome!
I'm going to play a bit with my subtimings and see if I can squeeze a little more out of these awesome Corsair sticks.
http://img.photobucket.com/albums/v3...421FSB8GB2.png
Since 0401 has loosen tREF to 3120 instead of 16383 memory latency will be loose also
and also bandwidth but no as much.
Sure will make more modules compatible since is jedec compatible (7.5-15us for tref => ~1600T-3120T)
I think i will go back to 0219 or 0308, since my ram have no problem with that.
At this time i have Linux and not windows on main rig so i have not seen how much is the difference.
My 3.3 q6600 passes 24 hour blend prime which i tested a month ago, but recently i guess due to weather not sure in game ive got bsod twice.
I didnt think weather could affect my stability so much. I think its the northbridge which is getting to hot and already got a spotcool fan pointed at it.
Im on bios 907 at the mo will i see any better stability or lower temps with one of the newer bios's?
Thanks.
the lowered Tref and other timings in 1201 helped lower chipset voltages quite a bit. otherwise...they are all basically the same.
How do you make slash or backslash in DOS then? Alt gr does not work and all combinations differ from the ones I'm used to. Maybe that should be included in this guide?
I just type a forward slash or a backslash and it works?
Anyone see this yet?
New Maximus Formula II X48
http://www.xtremesystems.org/forums/...1&d=1210370479
drool
You don't have the forward and backslash keys?
wtf kind of keyboard do you have?
"/" is the same key as the "?" key
"\" is the same key as the "|" (pipe) key above the enterkey or below shift key on the right, depending on what modle keyboard you have
MF 1201 and RF0401 are the best bioses released up-to-date for me.
In previous MF or RF bioses, I'd get occassional DET RAM hang whether my system is stable or not.
I've just finished 2 days testings with diff config with both MF1201 and RF0401 and I've NEVER come accross with DET RAM hang ever.
It doesn't matter whether my OC'ed settings were Prime/OCCT stable or not, the system hasn't encountered any DET RAM hang issue yet.
The stability is greatly improved from either bios.
XT
Isn`t it P45!? Or did you make a joke? XS.de would be great :D
http://www.hartware.de/news_44728.html
