beat this E8400 4.45ghz 1.344v 27/7 my tfrc is set to 30 at the moment this screen shot is a few days old..................:up:
I am not sure what you want me to beat.. I can use windows and run a easy benchmark like everest cache/mem test at 4500 mhz with that v-core, but for me that means nothing.
A overclock for me have to be intelburntest stable or else i won't use it 24/7
Try post a screen with that speed and a 5*intelburn test session, then we can compare. I did first get the chip yesterday, so just started testing.
Atm i will let run at around 4400 mhz with low voltage, because the only thing i use my computer to is gaming WOW and a litlle fallout 3, and both games run so smooth i can't feel any difference.
It's not logic, you have to admit that, you are able to cool a CPU below ambient temps with non chilled water...also your load temps are amasingly low... your sensors are for sure borked at idle, probably too under load... Tjcasemax selected is 95, I would set it at 100 or 105 for more realistic values...
These readouts got nothing to do with realtemp, pure CPU mate... but it's a nice CPU doing those speeds, cherish it :up:
every thing you said was debunked from the start...because True Temp reads 27c idle on the same board and cpu and dosnt go over 49c on 100% 30 min prime 95...so like i said its Real Temp that,s reading the wrong temps...i said true temp reads 22c idle and i got a reaction....people wanted screen shots so i gave them...i never said i believe them
just a little friendly competition..:D..you said you had a golden chip..:shrug:..are you gona cry or live up to your claim....so far my chip does 2 hour,s of prime blend while watching you tube and posting at xtreme systems while at 4.45ghz 1.322v if you want me to run intel burn test i will but i can tell you my board and proc are rock stable....its all in fun...im just trying to get you to push your chip further
nothing stresses my chip like youtube and xtremesystems. A true stress test. Intel should learn from the best
:shrug: your new values are more believable and even 32°C idle is still perfect... be realistic if you tell us you got 77° ambient, it's hard to idle at a lower value not ?
Just a tip :don't be agressive in your posts as you will not make many friends with this attitude...
Look for anything after Q821XXX and you will be fine... E8600 is for sure EO ; most E8500's too , but with 8400 you need to be carefull
thats while running prime blend at the same time for 2 hous...:up:...more than a few times its been 2 weeks at 4.45ghz and it still hasnt crashed...i deem it stable...:D...i would hate to think im the only one who uses prime 95 to check stability.........any way im going to dump this UD3R for the new lanparty ut p45 thats when were see some real gigahertz.......
below is something i got done working on 3.0ghz with less than a volt that last pick it jumped to 1.008 after i stopped the test the board keeps bouncing between v-core even when its not on load..
looks like I will be in this thread a lot now. I just picked up a CO stepping e8400 for $120 at microcenter. I got tired of the insane volts my current chip takes. I can't wait!!!
This chip just gets better and better. Intelburn test stable at 4.420 mhz with 1.328 volt (using loadline calibration now). It can prime at lower volt, but again i want it to be burntest stable before it is good for me
http://img221.imageshack.us/img221/9...0mhzng1.th.jpghttp://img221.imageshack.us/images/thpix.gif
could be because of how low i set my v-core in the test keeping the heat down its also water cooled thats the only thing i can think of....when its at 4.45.ghz 1.344v..it jumps up to 49c on prime 95....but for the screen shots above i wanted to see low i could set the v-core at its rated speed of 3ghz which was 0.992v and it passed an hour and a 1/2 of prime
Where are you guys finding the EO revision these days?
got a c0. running this OC now. Stable using OCCT, PRime95, but not the Intel Linpack Test.. anything I should do??
http://img237.imageshack.us/img237/5...prime95gj1.jpg
List your system, CPU/Mobo/RAM etc. in your sig. It'll help everyone to know what you're running on.
I'd start by setting your RAM to cas 5 and seeing how well your board responds to NB voltage increases. It does look like you'll be in the 4Ghz 1.3vcore (+/-) crowd, though. It's good company for C0's.
Finally, i find pretty good E8400 after several bad tries. It's Q830B153 Batch with VID 1.1875V. It's working Ortos stable with 450x9 (4050mHz) only on 1.15V, 4.2gHz with Auto 1.18V. Tried also 4.5gHz, but it's need some more voltage. Pushed to 1.34V and stop the Ortos after 2 hours successfully running. Needed also increase CPU VTT to 1.26V and PLL to 1.64V. All that with air cooling Zerotherm Zen120. With good liquid cooling the CPU can be pushed to 5gHz, i hope..
I've got a bad E8400 E0 Q832A378. One of the cores always craps out while the other stays stable. I need 1.34v just to keep both cores running @ 4.05GHz. One core will keep running in P95 @ 4.27GHz with 1.29v while the other errors out. I need 1.43v to keep them both stable. That's terrible compared to other E0 chips.
Ummm, didn't anyone else catch this? I really don't think that is the case.......can anyone say "new world record" LOLQuote:
Edit: also what is the limit for my memory anyway? Its OCZ Reaper HPC 2x1GB DDR2 8500 .. Right now its running at 2.1V, 1770Mhz, fully stable and passes memtest. How much can I go with this memory?
If your picking up E8400 you need to talk the saleman to look for
(S-SPEC:SLB9J) That's the EO Stepping number..If I was you..I
would go in myself and stand at the processor case and look for
the number.I gave above..The pack date on my is 08/07/08
and the Batch#Q820A832 atlease look for batch in the 820's
Best of Luck:up:
Finished the system in sig a week ago, still tweaking it. So far, I'm noticing this CPU seems to want higher voltages than most EO's. Batch is Q832A161. Got it from neweggs NJ warehouse btw. Can get a 4.5G overclock, but it takes 1.4 vcore and running the FSB up around 500 makes my RAM wonky. Cranked the FSB down a bit to try some tighter timings on the RAM, but noticing the vcore needs to stay a bit high. Right now I'm running 450MHz Bus, x9 multy @ 4.05GHz...which wants a vcore of 1.36. I can pass an hour of OCCT at these settings.
has anyone experienced a need to boost Vcore after a while?
strange, but a couple of days ago my computer became completely unstable after 2 months of running super stable....random restarts often, and a couple of restarts that would end up in non-reboots; had to turn PSU off, and start over.
I bumped Vcore from 1.28750 to 1.29325 and a little better but still rebooted. Then up to 1.3000v, and almost good but had two more reboots. Up to 1.3250 and now it is stable again! I didn't want to run that high of a Vcore, so I went back to FSB = 430 (3.89ghz), and put the Vcore down to 1.2835 and now it is running perfectly fine.
my board is a Asus P5Q-E, see my sig for more details
Yeah same here, though I have a feeling I never had enough NB voltage to begin with (only 1.34v in Windows since February 2008). I also, however, never played a 3D game long enough to really stress test. I played TF2 max maybe 1-2 hours at a time. L4D has me playing 4hrs+ per session, and pulled some Windows file BSODs (which I consider not as serious as the typical IRQ_LESS_THAN_EQUAL ones). A few bumps in my NB voltage, and no more BSODs. But I can't help but wonder if my 2hour OCCT checks are simply not enough (compared to 3D stable).
Hell I could probably drop my vcore back to 1.296vcore, but I'll probably play it safe like an old man and leave it be. Load temps are what, 1C higher b/c of a 2-step bump in BIOS. No biggie.
*actually you know what? Maybe we did experience degradation, and we :banana::banana::banana::banana:ing babied our procs with only 1.3vcore. :|
