Originally Posted by
zinsco
Still having trouble with coming out of sleep. Had to uncheck using usb to come out of sleep because it wouldn't go to sleep with the usb enabled to do that. Now I just use the power button to come out of sleep. That works but not if I go any higher than 4.0GHz cpu and like 1333 ram. I can go 2000 on the ram with the cpu at stock speed but as soon as I start bringing the cpu back up I have to bring the ram down.
I can pass prime95, I can run over 20 loops with linx and everything runs just fine at much higher speeds like 4.5GHz with 2000 ram and vcore / vtt voltages in the 1.4 ranges all day long, but as soon as it goes to sleep I can't bring it out of sleep. The fans and everything will run but thats it, I have to turn the power off and reboot.
Any ideas. Do you guys use the sleep mode, or is that normal with higher clock speeds and having ssd's in raid 0?
