Oh wow all these 144's killing me. I got a 146 because I had read they overclocked well.
I'm @ 2.9GHz with 1.5v not prime stable. Had it running for 7 hours then it quit.
Could be a memory issue, but my ram is memtest stable.
I changed my TRP from 2 to 3 and that made things more stable so my prime run of 7 mins changed to 7 hours. Now I'm running a cas 2.5 to 3 and I will see how long it ran once I get home tonight. I'm at school studying on my laptop. :(
I want to hit 3GHz~!!!! I have a CAB2E 0546 UPMW on a DFI Lanparty UT NF4 Ultra-D.
Hopefully I can get things stable at 2.9GHz, then I will try for 3GHz. Any others think my baby can to 3GHz?
My temps are a bit off. I was using the stock heatsink/fan, not the heatpipe one, but the crappy one, so I went out and got an XP-90C since I already had a 92mm panaflo medium at home. Now my temps with 1.5vcore gives me about 52degrees celcius full load.
I think I should try reseating the heatsink.
I've read that just adding a dab of thermal paste in the middle does it for these AMD64 processors, but does it really?
How do you guys do it?
I think my temps are too high.
Comments? :)
