also if you look at the swiftech website it shows you it using sli :)
http://swiftnets.com/assets/images/p...alth-sli-2.jpg
Very nice, n3wbi3!!!!
sik newbie!!! another aussie up on here woohoo!!!
Scratchbuilt is th3 b3st!
Did a little more on the Kandalf today...
Still a ways to go...
http://img222.imageshack.us/img222/6...wid2002tt9.jpg
Needed to make a pump bracket.
http://img220.imageshack.us/img220/2...wid2006le9.jpg
http://img232.imageshack.us/img232/7...wid2017mb2.jpg
http://img219.imageshack.us/img219/6...wid2019gl4.jpg
The Oly needed some serious cable management...
http://img220.imageshack.us/img220/5...wid2037oo0.jpg
Hard to believe but yes the door did close over that mess...
http://img222.imageshack.us/img222/5...wid2039wr9.jpg
http://img216.imageshack.us/img216/2...wid2043nn3.jpg
The biggest challenge is the crazy door/reservoir with half inch ID tubing...the tubing wants to drag against itself r anything it can...
http://img227.imageshack.us/img227/9...wid2045ek5.jpg
Still have a piece of acrylic mirror to run in there to spiff up the bay side and make the loogo stand out..tomorrow.
http://img231.imageshack.us/img231/4...wid2049un3.jpg
I have not used the XSPC radiator so I sure hope it's worth the trouble.
ASUS P5ND2 SLI Mobo
Intel P4 D 930 CPU
eVGA nVidia GeForce 7900GT KO
With the following cooling components:
MCR320 Rad w/3 YL medium speed 120's
DDC3.2 w/Petra's top
D-Tek FuZion CPU block
MCW60 GPU block
Tygon 3603 1/2" ID 3/4" OD Tubing
EK 150 Res:
http://img460.imageshack.us/img460/4899/casesideut0.jpg
http://img219.imageshack.us/img219/1476/casetopjs8.jpg
Lights out w/UV bulbs:
http://img219.imageshack.us/img219/3345/uvflashhn6.jpg
http://img459.imageshack.us/img459/1...lfflashun3.jpg
Darker image but shows the UV fluid slightly better
http://img296.imageshack.us/img296/9...noflashau8.jpg
Gotta love a case jam packed with LC gear :D
LOL go aussie POWER ;)
Mine so far.
http://www.egraphixstudios.com/images/1.JPG
http://www.egraphixstudios.com/images/2.jpg
still need to tidy up cabling a little more-especially pump side..
specs:
Lian li pc343b case + home made side panels. :clap:
Q6600 o/c to 3.0ghz for now. i dont even see the need for more power atm:rofl:
bfg 8800ggtx oc 630/2000mhz
gigabyte Dq6 mobo.
120.3 rad (on blue loop)+120.2 rad (on yellow loop-yes its yellow!! not green.)
4gb corsair dominator mem.
150gb raptor+hdd water block
2.5tb of additional storage (yellor and green sata conenctions :P in the pic)
a bfg physx card which was DOA...hmm..:down: will get a refund and use money towards something else.
will post more pics soon... what you dont see is the alphacool lcd which is mounted topside (since my case sits on the floor) its easier for me to read the panel.
I LOVE the two pumps and different colored fluid!!! A couple suggestions from a modding n00b (so take them with a few grains of salt):
1. Paint your PSU or get an acrylic PSU cover from Performance PCs.
2. Cool Sleeve the ENTIRE set of tubing or sleeve none. You can use metal inner sleeves if you need to for the tight bends. Just make the appearance consistent.
3. Toss some blue Yate Loons on that rad for color.
http://img229.imageshack.us/img229/4899/floorqs1.jpg
http://img210.imageshack.us/img210/8843/backck9.jpg
http://img210.imageshack.us/img210/3378/sideav9.jpg
http://img211.imageshack.us/img211/7339/cybergf5.jpg
:D
http://img229.imageshack.us/img229/9...used014et7.jpg
Wish I could test run the loop--waiting on fans for the rad.
is it glass?
cyber can we see the mirrors on teh ceiling over your bed?
for some reason i didn't think the mirror acrylic would look that nice!
I think it might be a bit much--gonna wait and see what the client thinks. I like the case floor though--it's about the only time you get to see the underside of your X-Fi :p:
yeah, the floor panel looks awesome. the side part, for me, is a bit much.
Luckily it is easy to change out. In a mirrored case you better not have any ugly spots :p:
what the hell... at first i thought he sawed his case but then it said it was a mirror lol
Hey CyberDruid: this you here?
http://i44.photobucket.com/albums/f9...CyberDruid.jpg
damn, that mirror finish sure is shiny...
:D
That may be him.
If you want some better pics, I believe this may be him here.
http://www.xtremesystems.org/forums/...9&postcount=37
This is just a question out of curiosity, when did this become a work log thread?
Where do you get the mirrored acrylic?
