Where do you read the batch # (sticker or PCB, or iC's), cause I got 2 good sets too, and just wanna note for the record. Do you know what chip IC #s yours has? I do know mine are the early double sided 16 ic black PCB. I will state that the stock aluminum cooling is poor for what they need. I replaced w/ ThermalRight HR-07 quickly, since the aluminum models were barely making contact with half the ic's. Again, as I stated way back, this was a big issue, but easily solved. I too can hit 1300MHz but 1266 is more steady for heat and vdimm. Just cool to know they can. I never needed more then 2.28v w/ trd 60 to 1266MHz. 2.22v @ 1153MHz trd 50.
Well batch is somewhat misleading since on the stickers there is a batch number, but most people here talk about a batch using:
