update:
Opty 146 CACJE 0607 APBW @ 2900, 1.54v
http://img132.imageshack.us/img132/8...able8gz.th.jpg
update:
Ok some primetesting and this is the result...2900 crashed after 53 mins... 2850Quote:
Originally Posted by daysleeper
ok result, not amazing but its fine i think... :rolleyes:
OPTERON 144 CACJE 0604BPAW 320HTT*9@1.39V under watercooling
http://img250.imageshack.us/img250/3...awvcore8jm.jpg
http://img325.imageshack.us/img325/6...pawtemp5ry.jpg
Opteron 144 CAB1E 0614EPCW 3100Mhz@1.425V under aircooling
Pics to prove that?Quote:
Originally Posted by Killer89
Here is pic at 3200mhz with 1.55V:toast:Quote:
Originally Posted by celemine1Gig
http://img210.imageshack.us/img210/4157/32004ki.th.jpg
Temperature was so low because my room window was opened:D Cooling is Freexer 64
That's a pretty nice chip Killer. I got a 148 a couple days ago. Trying it out last night, 32m Pi @ 3300mhz and a 1m @ 3496. 1.63v. Will do more tonight.
http://img.photobucket.com/albums/v1...2532m33301.jpg
http://img.photobucket.com/albums/v1...25/5251m23.jpg
looks similar to mine that oneQuote:
Originally Posted by coop
you should be able to do 32M in mid to high 34xxMHz
Those CAB1Es are fine. Mine will run 3.1GHz on stock voltage and TCCD ram. However I am currently using BH5 and I have bumped the Vcore a little to address the memory controller issue and have gotten to 3.2GHz. I would like to go higher but I would hate to fry this proc.
Opteron 165 CCBBE 0610DPMW, 3.0GHz on air. Bootable en stable in windows. Not 100% Prime stable (just few hours), need more vcore for that and therefore water.
My Opt 144 CAB1E 0604CPMW is runing SP2004 v24.14 now @ 3006MHz 1.37V AIR cooled :)
...waiting for Conroe :D
your blend test is not valid. only 1 test passed in 20minutesQuote:
you must use less ram because prime used your swap. that's the reason you have only 37° "load" with your freezer 64 pro :p:
whatever, week 0614 is the best week i've ever seen for opties :)
i'll receive Ã:banana: CAB1E 0614 DPCW soon and it"ll do 3GHz on stock volts aircooled
I've done four 32m pi's with this chip. The one above, a 20.37..a 20.36.. and this one, a 20m35s :[IMG]http://img218.imageshack.us/img218/9374/vvf2zo.th.jpg[/IMG] .
Also did a validate for the heck of it..3663. http://valid.x86-secret.com/show_oc.php?id=98026
May try more tonight as I believe it can. So far it has done everything all the way through. The validate could also go higher I think as I did not really want it to blink out. It is a 0543FPMW. I have to run with SysTool on to monitor temps.
Yep, B1 chips are just as impressive in single core as they are in dual core chips :eek: Where did you guys get your 0614s? I have a CAB2E 0602 coming, should be nice :woot:
cpuz validater...3.7Ghz http://valid.x86-secret.com/show_oc.php?id=98257
And a PB 32m SuperPi for me..20m32sec :D http://img228.imageshack.us/img228/8052/fff4ht.th.jpg
3006MHz @ 1.37V SP2004 v24.14 stable for +16h
Opt 144 CAB1E 0604CPMW and TT BigTyphoon :)
any idea what can i tweak in my bios to stabilise my 305x10 overclocks ?
other than vcore that is.
and also whats the max vcore i can go while not killing the chip?
Opteron 146 CABYE 0540FPAW @ 3.00ghz Swiftech Apex Ultra Cooled 1.58v
http://img233.imageshack.us/img233/5...zvx250s6jy.jpg
I recieved a 0530 CABNE today, here are my stable results.
http://valid.x86-secret.com/show_oc?id=98573
I'm rather happy with it.
A 32m Spi with my 148@3588 http://www.xtremesystems.org/forums/...&postcount=174
Opteron148 CABYE 0543 FPMW @ 3.15GHz Water Cooled 1.53V. Prime not stable since 3.0GHz...
http://www.vmodtech.com/files/3150-pi32m.jpg
what stepping is that?Quote:
Nice oc, i'm planning to chuck mine(same stepping) under phase fairly soon. Does your chip run hot on air, as mine has always been a hot one?Quote:
Originally Posted by Kain XS
hi all.
here is my new opty 144 just received today.
tested under freezer 64 pro with 23-24°C ambiant temp, ihs on
stepping CAB1E 0614DPCW
very nice chip here
http://membres.lycos.fr/starostise/C...prime95min.JPG
some new test with this opty.
awefull coldbug at 390 HTT for +40°C :eek:
so it's only good with air/water and stability.
max spi 1M:
http://membres.lycos.fr/starostise/C..._spi_1mmin.PNG
max screen always aircooled:
http://membres.lycos.fr/starostise/C...39-air-37C.PNG
