Zen is running his ram at 2.26 volts (bios) unless he has changed something
This was caused by the processor. Some of you may remember that I got a new board and continued to have the problem. It APPEARED as though all I had to do was hold the power switch for five seconds to restart after a failed BIOS restart. Despite 8 hours stable, other instabilities became evident. I got a new E8400, and that seems to have returned everything to normal.
Just an FYI in case someone else has the same problem and suspects the board.
Very odd mate ....
I got this mobo as I thought this would allow me to get the most out of my q6600 and ram , and thats why I got a gx2 over SLi - to suit this mobo and combo . The issues with this are getting too much - the cold boots , ram issues and fsb limitations they impose - I hope they sort out a nice fast bios for us before I sell up . I would like to see a 4870x2 or a 9900GTX on this , unless I sell up first .
:shakes:
I wouldnt sell up just yet aussie, I know this board has got some issues but its mainly to certain brands of ram (namely Crucial).Apart from that I think its a great mobo and with the right ram and bios, this thing works really well and very stable.I've had no issues with it except the ram. My Tracers should be comming back in a couple of days.I'll give them another go with the 1201 bios, and see how she goes. If it kills my sticks again, I'll toss the Tracers and get some OCZ or Corsair.At least I know there is no issues with these and lots of guys & gals are getting very decent numbers.
Yeah I would rather hold onto this mobo and sort it right out in time for new vid cards release.
:up:
Everyone keeps saying this. Exactly what sticks are you guys talking about?(I'm not saying it's NOT an issue, just wanting to know what sticks in particular) The single sided 8 chip PC8500 are terrible for sure, but that's on any board. I just popped a pair of double sided Ballistix PC8500's batch 16fd5 in and they run great at 1300DDR(650Mhz), I benched with them all night and I didn't even start tightening up timings. I did have to manually adjust the skew.Quote:
http://home.comcast.net/~aicjofs/everest.jpg
What does bug me is that I just can't get 45nm CPU stable at 450MHZ FSB, 440-450 seems to be about the max I can get and even that is hardly stable. So I am forced to drop way down to 430 range for stability(something that will Prime for at least 8 hours)
http://home.comcast.net/~aicjofs/superpi.jpg
Heh...sorry my Ballistix only come out to play on special benching occasions...lol. They stay in a drawer until bench time. I have 4 of the 16fd5's and I can't sell them to anyone(for a reasonable price anyway) because no one wants to buy them after all the bad publicity(and rightfully so, way too many sticks of the PC8500 died around the world)Quote:
I just wished you posted this 1-2 days earlier and I would have had these cherry picked sticks in my apt.
ok, i'm stuck, hopefully some of you guys can point me in the right direction. I started doing a serious attempt at methodically overclocking my q6600 g0 to 3.8. I got my first glimpse of stability at 5 hours prime95 doing small fft's. I'm running the rampage 0308 bios. Here's my last stable settings (they're not complete, but you get the general idea)
FSB - 423
Multiplier - 9
Strap - Auto
Memory clock - 846, timings on auto (5-5-5-15)
Clock twister - lighter
no other settings fiddled with, except loadline callibration on to help vdroop and both spread spectrums disabled.
cpu voltage - 1.50625
Nb - 1.53
FSBT - 1.52
DRAM - 2.01
cpuPLL - 1.62
^^ these are the values set in bios, btw.
So I got 5 hours with those settings before a BSOD. I thought I would up the FSBT to 1.54, so I did, and then only got 2 hours before a crash. I don't know what is keeping me back. Can someone please help me out? I know I can be stable at 3.8, i just don't remember my old "sweet spot" settings.
edit: my memory is 2x1gb sticks of crucial ballistix tracers 8500. i don't think any of my other components come into play here.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 450
FSB Strap to North Bridge : 400
PCI-E Frequency: 110
DRAM Frequency: DDR2-1200
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 18
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 50
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong
Transaction Booster : Manual
Common Performance Level [6]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
CPU Voltage : 1.56875
CPU PLL Voltage : 1.62
North Bridge Voltage : 1.59
DRAM Voltage : 2.26
FSB Termination Voltage : 1.56
South Bridge Voltage : 1.050
CPU GTL Reference : 0.67X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : DDR2-REF
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1.5
:up:
Wow!!! I just need to point out to those complaining of Crucials going bad too soon on any mobo is often this, set too high BIOS vdimm, knowing this mobo overvolts, and not cooling propperly. and since most are just stressing the rig 24/7 till it dies, no wonder. If thats what you like, cool. Racers do it, build an engine for 1 race and do it again next week. If you can afford it, go for it, just for the scores. I'm speaking mainly of the Crucials, but 3.5v is way much for any D9 or RAM for that matter w/o good cooling.
Where do you read the batch # (sticker or PCB, or iC's), cause I got 2 good sets too, and just wanna note for the record. Do you know what chip IC #s yours has? I do know mine are the early double sided 16 ic black PCB. I will state that the stock aluminum cooling is poor for what they need. I replaced w/ ThermalRight HR-07 quickly, since the aluminum models were barely making contact with half the ic's. Again, as I stated way back, this was a big issue, but easily solved. I too can hit 1300MHz but 1266 is more steady for heat and vdimm. Just cool to know they can. I never needed more then 2.28v w/ trd 60 to 1266MHz. 2.22v @ 1153MHz trd 50.
Many Crucial ram kits are dying with NO overclock even running below stock volts. The web is full of these reports. I do agree with you that 2.26 bios 3.5 actual is way to high for 24/7 use for a few hundred points in Everest. In a real world enviroment you could not tell personally from 1200 ram to 1080 ram, even 900 ram running 4-4-4-12 would be very close.
However this is EXTREME Systems not Mediocre Systems
Yes, the crucial single sides dimms are just plain crap. They are very often appearing doa or crapping out after normal use(no ocing). It is a pretty sad day when you say crucial and as an enthusiast say stay way. I really can't wait until they start producing better dimms.
I dont know about the others but my Tracers were at stock when they died.I never had the chance to OC them.There's too many people having issues with these OC'd or not to take notice. I was speaking to one of the techs at Crucial yesterday and he admitted they've had heaps of RMA's on the x38 and Maximus, now thats not to say they are all bad, maybe its a bad batch or simply a bios issue like he said. I'm expecting my returns anyday and I'll have another go with them.The last thing I want to do is get rid of them (love those leds:yepp:) but if they give me problems again with this new bios, I will toss them:up:
can anyone help me with my 3.8 overclock? I posted my settings up a few posts ago, was wondering if some of the regular posters in this thread could give a few tips.
Sorry for the late resonse, haven't been online for a few days.. I have the exact same problem w/ a USB 1.1 HID device I'm developing, it would drop the connection randomly once or twice over an evening. Moved it to the 2nd case port and it worked ever since. BIOS 1004, haven't tried 1201 yet. Not using S3.
These are my settings for 3.825Ghz and 8GB on Max Formula running with RF bios 0401 (highly recommended):
Extreme Tweaker
FSB Frequency : 425
FSB Strap to North Bridge : 266
DRAM Frequency: DDR2-1066 (4:5) or you can sett to DDR2 850 (for 1:1)
CAS# Latency : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
Row Refresh Cycle Time : Auto (for 52, can't be set manually in bios)
ALL PRE to ACT Delay : 6
ALL PRE to REF Delay : 6
DRAM Static Read Control: Auto
Ai Clock Twister : Auto
CPU Voltage : 1.5250
CPU PLL Voltage : 1.50 (had it at 1.66 at one time, I guess it had no effect)
North Bridge Voltage : 1.65 ( a little high because I'm running Oc'ed 8GBs at 1066.
DRAM Voltage : 2.1v
FSB Termination Voltage : 1.38
DDR2 Channel A REF Voltage : Auto
Hope this helps. :up:
1.52 seems pretty high for a E8400 @ 3.8GHz isn't it? My E3110 could do 4GHz with 1.3. Does the X38 chipset require more voltage clock-for-clock compared to say the P35 or P965?
I was wondering if that voltage sounds about right for my q6600 g0. The temps are awfully high, but I don't know if I'll be stable yet.
Think he's referring to Q6600 voltage settings Ghost Recon, hasn't updated his sig ( only 2gb ram there too)
hmmm I think I have my ram issues greatly improved now , passed memtest at 1081 where it wouldnt pass at 450 before , but its still unstable , I just want to bench at 4ghz (or 4.1 lol)
:up:
