Ahah just giving ya a hard time with that water pump :p:
Cata is right, it has to be a antec solo that you inverted by switching the cd drive bay around
the copper one looks like a little moldy on the bottom. you should probably send that to me so i can re-finish it for you... ;)
Moi? :D
http://img5.imageshack.us/img5/6133/1001359e.jpg
That's with my two new Palit 285s and Asus Xonar Essence STX. I would have liked to get an Auzentech X-Fi Home Theater HD but they aren't out yet.
@ croto5000 - good idea :)
Some lapping:
http://farm4.static.flickr.com/3581/...ba3bd4f1_o.jpg
http://farm4.static.flickr.com/3392/...df7b0d24_o.jpg
http://farm4.static.flickr.com/3540/...8aaac61c_o.jpg
http://farm4.static.flickr.com/3361/...4410f2c8_o.jpg
http://farm4.static.flickr.com/3406/...65e48ee5_o.jpg
those are some seriously shiney bases. excellent work sir :up:
Why not? As long as you get the correct lighting, exposure, and have the focus right, you can take good pictures also. And also, tripod is a must:) If tripod is not handy, at least try not to hold your camera in your hands:rolleyes:.
Remember, you don't necessarily need a good camera to be a good photographer:yepp:. A real photographer can take good pictures no matter what camera they are using:up:.
^ Nice as well as interesting. More details?
@poparamiro:nice coolers you have there my compatriot. tine-o tot asa man!!!
oh wow, even the lighter Mushi vga cooler can slightly bend cards a bit
how in the world did you get that so shiny!!!!?!?!?!?!
Really Nice work
Is that some fan controller? GPU fan is connected to it.
Also..
How are NB fans connected to heatsinks? I see no wires, screws... etc. There is a photo of two of these smaller diameter on acclero-like-gpu-air-cooler scythe or something.
I like my noctua C12P :D
No lapping done...out of the box condition...
http://img.photobucket.com/albums/v4...5/P1020626.jpg
http://img.photobucket.com/albums/v4...5/P1020642.jpg
http://img.photobucket.com/albums/v4...5/P1020636.jpg
ragnarok95 any more pics of the full heat sink?
cool pics guys! keep em commin!
Nice everyone keep it coming. Hey ND4 where's your rig pictures? :-p
It's FINALLY DONE!!!!!!!!!!!!!
THE PITA OF MEDIA
Specs
Intel E8200
Asus P5Q pro
Gskill 2gb ram
Lite-ON DVD+-RW
WD 640GB BLACK
Anyware MCE Remote
Galaxy 9800gt (non reference)
Happage 1250
Linksys Wifi G
X-FI xtrememusic
ARK Black Aluminum / Steel HTPC 400BA Case
Coolermaster Silent pro M 600w
Heatsinks:
HR-01 4u
HR-03 r600
HR-05
HR-05 IFX SLI
HR-07 duo Low
HR-09 Type 2 X 2 qty
HR-09 Type 3
HR-11
Fans
Exhaust Scythe KAZE JYU SLIM SY1012SL12L 100mm
Intake Panaflo 92x25mm 2100rpm FBA09A12L1BX modded to 5v @ 875rpm
Exhaust 135mm fan in PSU 800 - variable fan
Accessories:
Lamptron case damping foam
Lamptron PC silencing kit
Techflex non fray sleeving
Thermaltake sleeving
3m thermaltape
3m ceramic thermal pad
Krylon Black spray paint
Vespar Gold spray paint
Mods:
Months of planning before deciding on hardware to use for the build. Interior spray painted case. No Stock heat sinks anywhere. Passive build relies solely on negative pressure under airflow path cooling (similar to most dell systems). Custom spray painted gold I/o back side and pci parts. Black spray paint for some pci parts for black pcb.
Time to make this? Over a month.
How much I spent? Too embarrassing to say, you do the math.
Why it's called it PITA? It was PITA during installation, that's why.
More to come for images and updates. Subscribe people
http://www.hostthenpost.org/uploads/...0d5acb627e.jpg
http://www.hostthenpost.org/uploads/...b0e3ee3f1a.jpg
http://www.hostthenpost.org/uploads/...8e3c2f1762.jpg
http://www.hostthenpost.org/uploads/...5c740ebe75.jpg
http://www.hostthenpost.org/uploads/...0e668d3033.jpg
http://www.hostthenpost.org/uploads/...1bf2fd99c5.jpg
http://hostthenpost.org/uploads/9d6f...4ac3c9da77.jpg
http://hostthenpost.org/uploads/95e1...87a7617d06.jpg
http://hostthenpost.org/uploads/fcc4...e3b3704693.jpg
