Darn ... I feel so dizzy by looking at those tubes ...... :shocked: :shocked:
Awesome setup .... :up: :up:
duh... thanks. so many freaking tubes, my eyes were going crazy! :D
I saw his system already on a dutch forum. He claims to have CPU temps around 34c after 8 hours stress E6600@3900Mhz at 1.6v ...
But it looks really good. :up: No doubt about that. :)
vin_tech man that looks crazy dude.. in a good way :D
@coolfris those temps are totally possible only thing you need to do is to have a low ambient temperature.. something like leaving the window open in your room will result in those temps..
yeah, those temps are pretty low... especially for everything on that loop. like you guys have already said, it must have been winter with the window open. or he put the thing in the freezer. :D
My 1st WC buildup :p:, Hope you guys like it.
http://img223.imageshack.us/img223/2...g1208reaw5.jpg
http://img249.imageshack.us/img249/9342/img1815xr2.jpg
http://img249.imageshack.us/img249/2172/img1822fs1.jpg
http://img223.imageshack.us/img223/5590/img1829vb5.jpg
Thank you XS :up:
ANP !!! what tubes are there ? Tygon ?
vin_tech going to try to do the same with mosfets on my mobo, had a set of those mcx blocks gathering fust anyway, might be do the trick and let me get rid of that little anoing fan :)
Nice job Darkatom. I was just hoping that you or someone else on the forum could shed some light on the screws and washers you used and how exactly its connected to the top of the case. A shot of the top panel from the inside would be great if possible.
I am ordering parts for my wc setup and this is the part that I am stuck on. I want to top mount my 120.3 with 3 fans in a pull configuration. I am pretty sure it goes screw -> fan -> rad -> spacer -> case -> washer. I just wanna make sure the size/type of the screw, size of the washer, size of the drill bit you used to drill the hole for the screw, and size of the spacer you are using. Ive read about people using screws that were too big and puncturing their rad. Most likely I would try to order them from www.mcmaster.com or homedepot. The hole for the tubing looks like a 5/8' ID hole?
Thanks for any insight/links to mcmaster.com you can give on this.
sik stuff mate @ vin-tech one of the best rigs on here imo
Running off 1 pump? Man it would struggling so bad......3 rads so many block's If i were your d5 i would of packed my things and left a long time ago lol
Nah you can't be.... 3 rads 1 million blocks and 2 resevoirs???
what are your temps like?
Hi to you all!
very new to this forum, actually this is my 1st post anywhere! just wanted to share my badly taken pics of my baby which has been given the water treatment.
Got loads of ideas from peeps in this forum and am very thankful for their ingenuity:up: . AndyM, Ladderman and Pie_UK spring to mind but there are prob loads more i need to mention.
ka lok => where u have radiator and pump ? Can I see photo ?
Very nice setup,good cable management :) Good work...but with UV it will be great :D
looks like pump/rad is in the section below... lian li case i think. i love the clean white look (actually what i'll be doing except with blue colored coolant). UV would ruin the cleanliness of it. :D
Does anyone know anyone who has an eVGA 680i with watercooled south bridge and a 8800 GTX? I am trying so hard to find a water block that fits/clears the 8800. I intend to go to a watercooler for the 8800 GTX, but I need to know it's all gonna fit!
http://img300.imageshack.us/img300/2451/test055na8.jpg
http://img296.imageshack.us/img296/2460/test070ai2.jpg
http://img296.imageshack.us/img296/5615/test058he5.jpg
http://img187.imageshack.us/img187/4182/xr1006yx8.jpg
http://img212.imageshack.us/img212/1161/xr1011gm6.jpg
http://img295.imageshack.us/img295/6595/sept140gl9.jpg
http://img171.imageshack.us/img171/8725/mono3020pv6.jpg
http://img205.imageshack.us/img205/797/blood028ef8.jpg
http://img211.imageshack.us/img211/652/blood027nz4.jpg
http://img233.imageshack.us/img233/4...tt2r015ku6.jpg
http://img83.imageshack.us/img83/575...tt2r018jc4.jpg
http://img138.imageshack.us/img138/7789/done037zu8.jpg
http://img133.imageshack.us/img133/2116/done033fp9.jpg
http://img147.imageshack.us/img147/5983/done027ge2.jpg
Abit OTES on a Asus mobo LOL sacreligious! ROFL :D
I agree...but a Corsair cooler on G Skill would be even worse heresy...
which DFI mobo is that fluoro green one again?
