Same problem here. It seems to fail if you want to tweak the BIOS right away. But if you first boot with stock settings, reboot and then try again, that seems to work.
Also be careful when loading OC profiles. Mine set vCORE to over 1,6V (E5200)!
I dont know whats wrong here... i cant even get it to go 445, what am i doing wrong? i need some help here with some OC, apreciate it.
http://img149.imageshack.us/img149/7641/teste4am2.jpg
seem some ppl working fine with 1702/1703 but many ppl have problems
for me used 1611, from 1306 to 1611 (1406 wont work for me)
For all lads that have problems downgrading the bios plz look at this post ; either you take the hard way (swap bios chips and hotflash ) or download that AFUDOS version which seems to work nicely
Link here : HOW TO DOWNGRADE ASUS BIOS
Not sure what they've done to the 1702 BIOS but my system now boots like half faster. I just fire it up, makes like 2 sweeps of progress bar and i already see the Vista orb glowing. Anyone else noticed this or is it just a random display?
Is it possible that system now works better with all 4 memory slots filled?
Oh, also how come they made such a huge version jump?
for whatever reason, it seems that i have to use more NB volts than i was using in 1406 version.
however, 1702 may be improved on with some of a better RAM compatibility it has shown some improvment with my hardwares at least,
so as of now, i like this bios version better. it's about time asus released a new bios like this for this board model.
http://img257.imageshack.us/img257/5...8211319ab5.png
use the HP bootable usb tool :up:
the full explenation is in the thread mate. Just read it and carefully follow the instructions. Your USB stick will load the flash program automatically (if ya set the bios ofcourse to boot from the stick )
Works like a charm, too bad he only has the util for Asus mobo's...
you don't have to go that way ...
just download this version of asusupdate (flash in windows) http://dlsvr02.asus.com/pub/ASUS/mb/...sUpdt61002.zip
!Attention!
uninstall previous version of asusupdate and run "ccleaner" you can download here http://www.ccleaner.com/download/builds
than you were able to flash back to an old bios.... if you not run ccleaner asusupdate will show you the same red error message that you can't downgrade...
I did downgrade with that asusupdate version obove last night ;) and it worked perfectly
I have a crossfire HD4870 setup on my board: great GPU performance in gaming with the CPU overclock too, but I struggled with the heat and noise in normal day to day computing
I replaced the stock coolers with Accerlero Twin Turbos (which fit a variety of GPUs). Much better coolers: less noise and much lower temps/noise in normal computing
http://www.arctic-cooling.com/vga2.php?idx=166
This is just a headsup that they work on the P5Q board in a Xfire config, just fit
Couple of snaps here, had to mod an Antec P182 case slightly to get the lower cooler mounted - cut a hole
Yes there is duct tape there to stop cable fray on the edges :p:
http://i122.photobucket.com/albums/o...e/3800x600.jpg
http://i122.photobucket.com/albums/o...e/1800x600.jpg
Loving the board, not going to move from 1406 bios unless there is something compelling released
:up:
Nice looking setup mac_69 - can we see some 3D benchies? :D
Q9300 460x7.5, 8GB (4x2GB) at 5:6 DDR2-1100, bios set vDimm 1.8v, vMCH 1.36v, moderate and PL8.
4x Prime95's running 1 thread each, with a lot of RAM being used and tested...
http://img68.imageshack.us/img68/474...9160602gb7.png
i was never able to run this 8GB ram set at the clock speed with vDimm 1.9v and 1.30-1.46v vMCH,
before 1702 version of bios the 8GB will only capable to do 4:5 DDR2-1100 at 1.80-1.86v (bios) and at 440FSB.
bios 1702.:up: :clap:
have sold my E8600 Q820A606 at the wrong time:rolleyes:
run right now with a QX6850,I again have bought a E8600 :)
NEW volt set in bios 1702
CPU VID: ??? what makes it good for:confused:
Some old benches in my sig
New coolers are great as I do normal computing 99% of the time, but I had read on the web and found out first hand that its not possible to overclock GPUs much with these quieter fans (compared to stock)
Got almost the same result with default clocks though, just under 20K
http://service.futuremark.com/compare?3dm06=9293881
I've forgotten my vantage key :rofl:
here whit the QX6850 8x500FSB bios 1702 Watercooling
had little trouble with the last test in 06,whit 513FSB:(
Not too bad. Have you tried settings CPU GTL Refs to 0.67x or higher? There's a possibility that you could go a little higher or lower your cvore at the current speed with some GTL tweaking.
Nice work, 500 & 513 FSB on a quad is good to see. What vNB did that require?
ty CryptiK
vNB 1.56v ;)
my computer does not restart, i'm using P5Q-E with bios 0803.
every restart, my pc is cold backscreen and not continue.
I have to turn off button of PSU and start again, it works but if restart, It continue appears black screen...
how can i solve it???
bios 1703 is so :banana::banana::banana::banana:, it canot work for me...
your ram gskill PC8000PQ work PL? at bus 1000???
same thing here, after updating to 1702 i lost my OC and had to unplug to get post screen, so far so good
