so i had a little tinker with my board and cpu a little more, and i am now running at 2.4ghz load temp of 46. After half an hour torture testing with sp2004, no errors as of yet running my pc3200 on a divider of 166 to bring it back up to 200mhz on this overclock. Cpu is at 1.350 volts which i believe is stock volts? although i set it to 1.350 in the bios, asus probe shows 1.38 and fluctuates up and down every now and then :confused: but does not go over 1.4 i think everything is safe and stable and i cant see the need to test the memory as its running at stock speed (200mhz). Although at 2.5ghz my cpu seems to hit a brick wall, it will boot just fine but once it gets to the windows loading screen it will just restart its self i think it may need more volts but im happy at 2.4 right now.
http://img127.imageshack.us/img127/6558/cpuz17da.jpg
http://img151.imageshack.us/img151/1000/cpuz29ot.jpg
http://img56.imageshack.us/img56/402/cpuz39xp.jpg
spec's;
Amd 3800+ 64 X2 LDBHE 0605FPMW Stepping
Asus A8R32-MVP Deluxe
Ati x1900xt 512mb Powercolor
1gb PC3200 Elixir 2x 512mb sticks dual channel running on divider of 166
Freezer 64
Hiper 580w Type-R Psu
Thermaltake Armor
thanks anymore help or suggestions is gladly welcomed :D
