Originally Posted by
[XC] 2long4u
No he copied me, and I copied Ssilencer, remember. lol
You can also use acetone to bond them together.
It is a little tricky as the solvent is way thinner then water. With acetone you would soak them but you would have to come up with a way to isolate your glueing surfaces. You might be able to use wax. I would give it a try with some scrap.
By soaking them the acrylic becomes almost soft. When both pieces are like this they will fuse together becoming completely transparent.
Edit: friction welding is no good for acrylic.
