thx, that's what I was looking for! :)
Hi,
Anyone using non-ES 'C' stepping Cedar mills ? Results ?
Some results with my new 920.
System is:
ASUS P5WD2 Premium - vcore, vdroop mods.
Intel® Pentium® D 920 @ 4800Mhz @ 1,56 volts
2x512MB A-DATA DDR2-800 @ 1030 @ 4/5/4/4/2 (BIOS) @ 2,3 volts
Point of View GeForce 6600 GT @ stock
Hitachi Deskstar 7K250 250GB
FORTRON FSP550-60PLN 550W
Cooling is:
Swiftech™ STORM
Swiftech™ MCP655™
HWlabs Black Ice PRO 3
Cinebench 2003
http://img52.imageshack.us/img52/8092/14oa.th.jpg
Super Pi 1Mb
http://img52.imageshack.us/img52/5060/24ex1.th.jpg
Super Pi 32Mb
http://img52.imageshack.us/img52/8321/35aw2.th.jpg
Sandra Memory Bandwidth - BUFFERED
http://img52.imageshack.us/img52/4108/44bp.th.jpg
Sandra Memory Bandwidth - UNBUFFERED
http://img52.imageshack.us/img52/7411/57jn1.th.jpg
EVEREST - Latency
http://img52.imageshack.us/img52/7598/63ww1.th.jpg
EVEREST - Copy
http://img52.imageshack.us/img52/4705/79jz.th.jpg
EVEREST - WRITE
http://img52.imageshack.us/img52/4201/80ho.th.jpg
EVEREST - READ
http://img52.imageshack.us/img52/8030/96hj.th.jpg
Does your 920D contacts 100% with the Storm ?
I has this because it seens that the 9xx don't have a flat IHS !
When I apply some thermal paste in the CPU center and put the STORM, the thermal paste spreads good on the whole IHS and on the block stays a nice layer too, so I think that the contact is very good. The temp at that speed running 4x SP2004 is 60c, and the ambient is 28.
damn i hate my mobo cos its holding cpu oc back:(
http://img262.imageshack.us/img262/4484/13203gp.th.jpg
anyways cpu can do 4200mhz with 1.325v and it is prime stable:)
wonder what that cpu could do with something colder and better mobo
dos your mobo stop at 300FSB?
no but it wont do tests over 4600mhzQuote:
Originally Posted by hot_fifty
ill get boot screen @ 4,96ghz but its not stable
mobo goes 325mhz with def voltage and overvoltage doesnt give anything
@winterwind: isn't prority 10 (SP2004) + large ftt better for testing the cpu stability?
btw: my 920 does up to 4.6ghz@1.49v aircooled.
raiden
Mine 920D has a bad core. The 2nd core is f*****ing my OC baddly.
To get 4.2 I must put at least 1,485v !
When testing the cores separatly the fisrt one is good. The second one needs more "juice" ! :(
http://img152.imageshack.us/img152/6...tled3qj.th.jpgQuote:
Originally Posted by Raiden Zero
had to but cpu voltage to 1,350v
my cpu does 4.5ghz with 1,45v but i dont need so much cpu power right now with my X700PRO
Originally Posted by jVIDIA
How do you test each core separately???
Task Manager / Process / Set Afinity ;)
But it can also be done (set afinity) in Prime95.
Hey, sorry for the late reply vanovich.Quote:
Originally Posted by vanovich
But that benchy was done with X800 XT vga and no Vmods. :)
But that benchy was done with X800 XT vga, not X1900XTX and no Vmods. :)
Iluvintel, those are some really nice clocks on that 641 on air.
Nice clocks indeed ! My 641 does 4800 Mhz only :hm: throttlefree with dual Prime95 for two hours. And that's on water...
Are there any applications (besides ThrottleWatch) to monitor if the CPU goes in TM1/TM2 mode?
Also, does anyone know if the multiplier of Cedar Mills is adjustable ? It would be great to raise my FSB more and run memory 1:1 with lower timings...
the multi is not changeable.. Mine does 5Ghz on air but not stable.. 4800 is stable at 1,3 volt on air
Thanks, epox4life. But my days with Cedar Mill have come to a close. Are now playing with 930 Malay packaged processor till' conroe becomes retail down here in OZ. :)Quote:
Originally Posted by epox4life
http://img109.imageshack.us/img109/7...hr1base5bq.jpg
Presler 940 @ 1.3v
cooler box
http://img84.imageshack.us/img84/632...olerbox3fs.jpg
Thermalright HR-01
http://img52.imageshack.us/img52/995...ivcorestoc.jpg
http://img102.imageshack.us/img102/3...txstock0mq.jpg
http://img240.imageshack.us/img240/6...txstock7cj.jpg
http://img240.imageshack.us/img240/7...rk03122212.jpg
Presler 940 @ 1.475v
http://valid.x86-secret.com/ccpuz.php?id=93268
http://valid.x86-secret.com/show_oc?id=93268
M/B :Asus P5WD2-E
CPU :Presler 940 (pack date 04/26/2006)
CPU Cooling :Thermalright HR-01(120mm x 1200rpms) room temp 23C
MEM :GSKILL F2-6400PHU2 2x512mb (Elpida)
HDD :Hitachi 80GB ata 100 7200rpms
VGA CARD :7900GTX stock
POWER: Zippy Type R
OS :WIN XP SP2
Cool heatsink there PC! Do it handle the heat good? Put a delta on it hehe.
PcC12iminal, you have Vcore mod on Asus P5WD2-E to get those clocks and Vcore for those 940 benchies ? :)
U get the allways the best... :)
My 940 tops @ 4.53ghz with 1.475v even with watercooling...
Don't you guys have the "IHS not beeing flat" problem ?
Presler 940 runs very hot and im using a Scythe 120mm @ 46.5CFM ,just enough for 1.425v ,Quote:
Originally Posted by NiCKE^
thats what i got
940 @ 4ghz idle
Ninja 55C
Thermaltake BT 54C
Thermalright HR-01 56C
930 @ 4ghz idle
Ninja 36C
Thermaltake BT 36C
Thermalright 38C
@IluvIntel
no mods my friend ,the drop is insane, 0.05v on load
this chip is new, april 26thQuote:
Originally Posted by JoeBar
i got a good one i think :D
what temps you got on load??
This is the first time i lap a chip
http://img85.imageshack.us/img85/957...apidado0sm.jpg
-12C :banana:
Presler 940Thermaltake BT
http://img117.imageshack.us/img117/1...dotemps4kv.jpg
vs 95w TDP
Cedarmill 4.5ghz Scythe Ninja
http://img104.imageshack.us/img104/6...lltoday5qw.jpg
room temp @ 23C
