Excellent! My new pump is here(broke old one) Should be back on water by end of week ;)
Results for my JIUHB 0302 XPCW 9...
http://www.xtremesystems.org/forums/...0&pagenumber=3
Need better ram.. 8-/
What kind of new pump are you getting N8?
Ztop,
Care to share what your water cooling set up consists of?
ONe heck of a OC ya have there.
N8, LTNS...where ya been?Quote:
cpu and north.....whith a wb....h20 4°......
Well, here's what I was able to get my XP2100+ to with water-cooling. Not stable though, but it just represents a high point that many people like to see.
http://www.employees.org/~slf/images/2766.jpg
That's an XP2100+ 0301, using my White Water CPU water-block cooled by a large dual fan radiator.
a little 2100+ test under plain watercooling @2.1v
http://digilander.libero.it/spaceboyz/2796.jpg
it did 3D at 2750Mhz
azz.....è tuo??
Hehe Spaceboy, I love your clean system, you just need to get rid of that clock in systray and you're set :D
:D
u were right 'bout 3D score ;)
i'll showe later
See ya in msn ;)
Hehe, I know I was. Btw. I'll begin game of catchup today, I got 8RDA too :D
http://www2.arnes.si/~mlivak/8rda/A3.jpg
A3 ready to rock&roll :D
leave one day please :D
http://digilander.libero.it/spaceboyz/compare1.jpg
WOOOHOOOOOOOOO, insane score there Spaceboy, now you realy set the bar very high :D
So this is No.1 overall 4200 score, incredible work m8 :toast:
Spaceboy that is simply amazing! :toast: Not only 18k but well over it :D :D ... Im 1 click from ordering a 8RDA now because of this.. Thought I should wait for the nf7 rev1.2 but I cant control myself when I see results like that ;).
edit: Whats your card clocks btw?
Yes, that score is amazing.Quote:
Plain water-cooled eh? Not sitting on the balcony on a cold winter's night by any chance? That has got to be the singular highest water-cooling overclock of an XP2100+, and the only ones I know of that are close that are water-cooled were chilling the water to get that far.
As for the GPU speed, also incredible. Just by looking at the Nature score it'd have to be touching on the 380MHz core-speed mark at the very least, and the memory would have to be well over 700MHz, which would also make that one of the most incredibly overclockable Ti4200's on the planet as well.
Such amazing luck.
Cathar, watercooling and voltmod on 4200 with chilled water can get to 370/700+ in most cases. I've done it with my el-cheapo 4200 64 MB oem Leadtek card. Those better 4200 can get even higher at least on ddr, gpu is pretty much maxed up at ~375 (well at least Riva tuner is :D)
knaSen,
Welcome to Xtreme :)
Test it & let us know ;)
thanx mate ;)
I sure will.. I will try it first in my shuttle when it arrives, and at a friends place.. he has watercooling so he will probably get higher than me :D
u got it :)
i don't speak english very well so. i thought plain watercololing was a correct description : i meant there wasn't any tec on the cpu but just a Waterblock an some very very cold water ;) How do u call it ?
Such amazing luck.
Yes the card was overclocked to 376-780
:D
Thanks guys ;)
W AMD :toast:
Can someone pleas advise me on this.
I wont to buy a new MB and DDR but i have just enough money for the:
Shuttle AK39N and 512 Samy RAM DDR333
or
EPOX 8RDA+ and 256 Kinston DDR333
:confused:
I have no idea which one would be the best pic.
I would go with second choice, and buy another 256Mb a little later when you can.
I just love this Epox mobo.
N8, where are you ?
I'm here I'm here sorry, got some catching up to do in this thread :D
We got snowed in w/ 30+ inches of snow over the weekend so it was a bit hectic...not much time to be on PC.
Did have time to test that 2nd JIUHB 0302 however & it hit only 2388MHz max @ 2.15v on air. Not bad at all but not great of course :D
BBL, got to read some more of this thread ;)
Another VIA Aqua 1300...broke the housing on my old one, oopsie :DQuote:
Dam busy! & not able to get on the forums much with the server problems...tho it seems to be ok this morning, & the server problems are being worked on!Quote:
Prolly get my watercooling hooked back up this week ;)
Well, good to see ya again. Water cooling, eh? I guess I might just have to try that out sometime, but I'm still a bit adverse to the idea of water in my case. ;) Maybe I'll outgrow my hydrophobia someday. :DQuote:
ive got to make a waterblock, itl be based on morplings design with few modifications
sadly my phase change chiller has some big problems, the elastic freon hoses LEAK
but the temps were fine, -33C is a nice temp =)
hmmmm... summing up this topic, which athlon xp1700+ is currently the best ?
