Nice XXMARTIN, how did you get that HS off?
ok, when Are you guys going to push these chips..
This is my 4200+ on Vapo LS and I have not even started tweaking :p:
Nice... is that 100% stable clock? :) I have feeling most x2 will stop around that clock for 4200+ with single phase around the voltage you are using... Still need to work on case and waiting for few things.Quote:
Originally Posted by hag6br
I had to raise the Vcore to slightly to get 100% stable.. But I also got it up to 2948 Mhz @ 1.56V..Quote:
Originally Posted by jinu117
But, The memory controller is just downright weak compared to a clawhammer or Winchester core. had to loosen timings where I can go 20 Mhz higher in FSB with my FX55 at tighter timings.
But with the dual core, time to put it on air and run some DC projects on it :clap:
to bad that it's far from stable with watercooling ...
http://mitglied.lycos.de/xxmartin99/...4RPMW/3000.png
http://valid.x86-secret.com/show_oc?id=28068
however, 2.9g may be possible dual-primestable
What did you use to get the IHS off? Single razor blade, X-acto knife, ?Quote:
Originally Posted by xxmartin
a very thin razor bladeQuote:
Originally Posted by p0tempkin
http://home.arcor.de/xxmartin/razorblade.jpg
read back a couple pagesQuote:
Would a 4800+ Be stable @ 3GHz with Watercooling? I see that the 4400+ Has a little trouble? Or do you think it would be about the same.
Little chance.......... :)Quote:
Originally Posted by Puni Puni Poemy
What directories did you put yours in? Can you just have two folders on the desktop with them in it?Quote:
Originally Posted by Ugly n Grey
Any two separate folders, regardless of location.Quote:
Originally Posted by burningrave101
Why do you say that? Lots of guys here are getting some wicked numbers, I think my 4200 chip would hit that if I could keep the temps down, I'm trying to make a deal on a phase system as we speak just for that reason...I'm at 2.85 on the stock cooler..... but it's burning HOT....Quote:
Originally Posted by pcdoc1
Yeah heat is an issue. Had exceptionally hot day today and couldn't keep stability @ 2.7ghz anymore =_=.... had to back down to 2.65ghz to keep the stability. I can't wait for few missing parts to arrive to fully convert over to phasechange and deal with it... Probably thursday is the day for me to hack the case.
Got mine...but bad news. Its not prime stable (2X) at stock speed! :mad:
RMA time I guest .........
That sux, make sure your board isn;t undervolting it some guys boards are....Quote:
Originally Posted by Charloz24
Nope isnt my board, tried it with higher volts (1.5V)...same things ....
Are you running prime from 2 seperate folders, two seperate instances running at the same time ? Prime will fail if you try just running it twice from same folder.
Also it could be your memory ;) Run memtest in windows and check your memory.
Should be receiving this retail part Wed from the Egg, ordered today shipped today excellent store indeed.
Also sitting here is a DFI UT NF4 Ultra-D and Wed will be receiving a XP-120 with a 114 CFM 120mm fan, case is a long server case (mainboard far from HDDs and many fans in there)
How well do you think I will be able to do on air with this? Incidentally I spent about 20-30 hrs this weekend (literally up all night and into the sunrise mornings) reading and trying to find a total answer for my FX-55 San Diego which I knew would clock to 2.8 ghz and give me the best gaming experience.
Finally after reading many results of the 4400+ achieving 2.4-2.6 ghz on air I was hopeful I could possibly match the FX-55 (stock) FPU performance for my XFX 7800 GTX Extreme Overclock card.
While I do love gaming BF2 which I bought 2x1GB (See 2x1GB/1x1GB OC Database) Crucial Ballistix (can't wait to test these suckers at full speed)
I still do some DVD to MPEG4 for PSP and I do work as a Senior Engineer for a networking company so my "multitasking" can sometimes be having several IE windows open with Outlook etc and naturally I run Corporate Antivirus in the background with MSN IM and some other items.
My final thing that "got me convinced" was the press release from Nvidia regarding multithreaded dual core CPU driver support giving 3-5% increase in gaming performance. I am hoping with the overclock of the 4400+ coupled with background tasks freeing up one CPU completely, and the nvidia dual core multithreaded optimization I can have the best of both worlds.
You can imagine how bummed out I will be if I can't at least get 2.4-2.5ghz completely stable after the cash I've laid out here and the XP-120 + fan + AS5 wasn't exactly cheap either.
Thoughts on my hopeful overclock of the 4400+? :toast:
I love my toys too !! :toast: now get some sleep ! lol
I am assuming you received the 4200+? Read my post a bit further up. Now you have me scared........... :eek:Quote:
If I have to stick at 2.2-2.3 ghz after $632 I am going to be :slapass: myself for quite some time
Did you receive your X2? What cooling? What kind of OC did you get? :clap:Quote:
Originally Posted by Major
Umm yes 2 different Prime in separate folders......Quote:
Forgot to say that also falling 2 instance of super pi 32 (in less than a minute)
I tested my mem with memtest86, but not in Windows....but hightly doubt that my mem is the fault...It is doing 300 fsb @ 2.5-4-3-7 and now is running 200 fsb (same timmings)
Go here and download "memtest" it runs in windows and test your memory.Quote:
http://www.benchmarkhq.ru/english.html?/b_e.html
Memtest86 is not the same as running in windows, I've had memory that passed memtest86 without errors that fails right away in windows.
Also, are you using all the extra power connectors on the mb ? the molex connectors ? you might want to try that if your not already.
Make sure you don't have the 5v jumper slected by accident on the mb for your memory too, I know your not using above 3.2v but may have left it selected at 5v by accident (I know I have b4) and this will cause memory instability.
Just suggestions ;)
Yes I use all the extra power connector on the mobo.....
And yes its not on 5v...
But thanks for trying helping me Major :toast:
