Originally Posted by OnBoard
Yes, got that RoHs thing, just tried to be funny with the comment, guess lead in motherboards (and other stuff) is coming more of an enviroment issue.
Oh and before I forget, put the mobmo cap on the testpoints (after 30min on the other pin, gave up for a good solder, it just would not make a good contact, no matter how I tried) but it works and fit is tight. So on with testing I went, first time ever I was able to OC so much that it would do artifacts on 3dmark05 (360 on core and 865 on memory), weird black and green polygons flashing here and there, but it went through. Played toca with 800 on memory couple hours, no black screen, don't remember for sure if there were no freezes also, have to test some more. I'll go for that 850 again 'cause it BS:ed so soon that it's easy to see any improvement.
EDIT: Tested toca a while with the 850 on memory and no problems :banana: so working like it did before and even better. Now that I have a working card that overclocks fine, went and ordered a new one :D Well someone gets a good and tested card for cheap and I get a faster one not so cheap :p:
Thanks for the comments/answers, made me wiser again. That capasitor lifetime was a real eye opener, so best way to go would be overclock memory as you need and not by bios mod, Have 325/700 12 pipes 6 shader bios in right now, was about to put 325/800 in for good, but have to think about it.
