how do i take the clips off?
use some creativity... ;) little bit of thinking goes a long way.Quote:
Originally Posted by calcal
PC4000 REDLINE XP4000 DDR500 (2-2-2-5-1T @~3,3V) --chip--> Winbond New BH-5 ~ Brainpower PCB ... thats wrong ... they are utt ch-5 !!
Someone Tell Me How To Take These Heatsinks Off Or Link The Instructions
They Dont Pop Off
My pqi TURBO DDR550 is using Hynix D5 + Brainpower 815 and it has a pmi sticker on it.
http://www.geocities.com/a_andlcs/MEM/pqi_DDR550_01.JPG
http://www.geocities.com/a_andlcs/MEM/pqi_DDR550_02.JPG
This is a nice report, thanks a lot! :DQuote:
Originally Posted by andlcs
(I write all the perfect reports on my .txt and after ~5 I update the list).
I know as I have written few posts ago ("directely from Mushkin"), I will correct soon. ;)Quote:
Originally Posted by Eloxxd
You must remove the metal clips. To do so, put a screwdriver or something underneath it. When done removing the clips, gently pull the heatspreaders off. Between the heatspreaders and the chips there's thermal tape.Quote:
thanks comp freak, the first part worked but the second part didnt. I cant pull the heat spreaders off, its too tight :(Quote:
Originally Posted by Comp-Freak
It's a start ;) You must lift the heatspreaders on the same side the contacs for the ram slot are. On the other side, the 2 spreaders are hooked into each other.Quote:
Just wanted to post that i bought a pair of Patriot 2x512 pc3200XBLK and i recieved them today. they have the BP 815U pcb (Thats RED pcb :) ) and the tccd 522 chips. i havent run them yet but suspect they will fair just fine...
peace perc,
Yeah, they will man! Report us your progress! :DQuote:
Originally Posted by Perc
so far these new patriot tccd 522 are acting more like my 256 tccd sticks then my older crosair 4400 512 tccd sticks... these 512's here will let me run 270/280htt at 2.7v and 2.5-3-3-8 instead of the 2.5-4-4-8@ 2.8v i had to use with my 4400 crosair tccd 440 memorys. im going to see if they run 300htt or not at these timmings? im sure they do but you never know...
peace perc,
I think PQI evolved out of what used to be PMI, didn't they?Quote:
Not bad man! Also the clock of your Dual Core is awesome! Let's see if your memory can do more! :DQuote:
over a year ago pqi bought pmi, so basically yes.Quote:
Originally Posted by serlv
lol yeah i cant complain about this dual core so far with these patriot 512 sticks im at 280htt 2.7v 2.5-3-3- 1:1 ofcourse... with my other crosair 4400 tccd i was running this core at 300htt just havent tried these new memory at 300 yet im sure they will do it np. heres a screen shot of 300htt using my crosair tccd...Quote:
Originally Posted by Punisher!
*edit* heres a screen shot of the new patriot doing 300htt 2.5-3-3-X using only 2.7v. compare these to my crosair at 300htt where i had to use 2.5-4-4-X using 2.8v id say these new patriots deff oc nice with even tighter timmings then my old tccd 440 crosair...
peace perc,
Hello
Somebody know what chips have OCZ EL PC2700 rev. 3.2 256MB sticks ??
SPD timings 5-2-2-2
Regards
Peter
:banana:Quote:
What about some benchies? :p: :toast:
i can post a few i supose. i just never see anything special about my mem scores so i never post them...
peace perc,
Just got my OCZ4001024WV3DC-K BH-5 goodness new stick's i think ill break them in right with some high fsb lovin :)
hi!
i've got a question:
i'm trying to to buy old bh-5/6 and i got a message where it was written that geil ultra pc3500 p/n MAG16UL6464D2TG4A-KT is winbond. but i dont have any info about the chips.
what do you guys think, could this be winbond bh?
ps if anybody sells 2x512 winbond bh5/6 pm or e-mail me please.
Black PCB no. Green PCB ,maybe.Quote:
Originally Posted by i found nemo
oh, on another post here on xs it said that it had utt chips :(
