What burn in procedure is better: with Memtest or with Sandra? Will unwackme-BH5-BurnIn help für UTT too?
Seriously ! I wanna make sure, if anyone have ever see anybody who overclocked a OCZ Patimum Revision II PC3200, that can handle with stability, with only 2.7v at 285Mhz 1:1 cas 2.5-3-3-6Quote:
Originally Posted by googles
Don't know if I count, but I hit 300fsb at 2.8v on the new DFI NF4 Ultra-D board with the OCZ Plat Rev 2.Quote:
Originally Posted by AMDfan
Of course I'm running VX at 265mhz, 2-2-2-5 @ 3.4v with the DFI NF4 Ultra-D. :banana:
Hey Andy did your sticks always do that speed or only after time?
Andy, maybe I've already asked it, but can you run your VX higher than 3.4vdimm without losing stability?Quote:
Originally Posted by andyOCZ
I've ordered a kit of VX from newegg b/c of this thread, and I hated my TCCD haha.
did anyone hit 300 with the vx? cuz i would really like to get me some ram that does 300 with 2-2-2-5 timings stable...
tell us if you found any. :)Quote:
Originally Posted by wfarid
too much :banana4: lately ??? :lol:Quote:
sure i'd believe you. my 3200plat rev2 did 285 2.5-3-36 @ 2.85v. it's not a stretch of the imagination that another person could do it at 2.7. that is of course assuming your psu rails are all at stock.Quote:
it's a dream man, a dream that may in fact come true especially with the new venice cores and san diegos that are coming out...
Anyone try VX and the 4vdimm on the DFI yet?
Prior to my Ultra-D's death, I had my jumper set to enable the 4V option. With 3.6VDIMM (unverified BIOS setting), I was able to run at 10x271MHz 1:1 2-2-2-7-1T 3DMark stable. I was also able to run 3DMark at 9x277MHz 1:1 2-2-2-7-1T with the same voltage. That's with 2x512MB modules, in case anyone's wondering.
I shipped my board back to Newegg for replacement. You can expect to see some screenshots from my end when the new board arrives. ;)
good TCCD surely can do that. my G.Skill 4800GBLA can do 283 2.5-3-3-7 with 2.6V...these modules are pretty good...Quote:
Originally Posted by jikdoc
Hi, a question: I'll buy a DFI LANPARTY UT nF4 Ultra-D. I must choose beetwen these VX and Geil Ultra-X PC3200/4400 (TCCD) ... which would you buy? I have understood VX modules needs much vdimm .... DFI vdimm limit is? 3.4v?
Thx for attention ;)
EDIT: another question ... I see G.Skill LE/LA or Geil UltraX 3200/4400 (TCCD) reaching 300 mhz but with high timings and VX reaching 260 but with aggressive timings ... what is it better? Can VX with higher timngs reach 300 mhz?
1. definately VX or Twinmos SP with UTT chips. DFi NF4 have 4.0v onboard.Quote:
Originally Posted by XiN
2. VX works best at 2-2-2-X. You can't get 300 MHz with the VX.
Uhm, ok thx ;)Quote:
Originally Posted by bwan
For a daily use 250x10 in your opinion what it is better? VX or TCCD modules (Geil UltraX, OCZ PC3200 Platinum rev. 2 etc...)?
Have tried up to 3.6v (board overvolts by 0.1, so is actually giving 3.7), however, at ANY speeds if running over 3.4Vdimm, memtest gives tons of errors. Ignoring that, I was up to 270x10 in Windows (with Clockgen) with my doggy cpu and subzero outside air coming from the window, was good for screenshots and playing around a little, but no serious benches, of course.Quote:
Originally Posted by =[PULSAR]=
:( My brand new VX is not even botting into windows @ 220 with 3.2V with my DFI ultra-D.
Does this stuff need that much of a burn in or....? :stick:
Try a little bit more voltage. ;)
3.4V and still nothing. Can't get even load windows, just reboots.
I've tried both sticks seperately and neither make it @ 215 :shrug: :brick:
Perhaps the shipping bios doesn't like VX?
My shipping BIOS did well with my VX. Try trading places with the memory. Just switch them around and see what happens.
Do you have active cooling for the DIMM region? Do you have another PSU that you can test?
Yes I have an 80mm fan on them and I also have another PSU I can try but its not as good. its an antec 380 trupower =/
I'll try tradding places with the ram.
What's the highest speed your CPU can hit? Try a lower CPU multiplier and a higher higher HTT.
Chip is 2.7Ghz 24/7 stable. Got VX B/c I didn't like TCCD.
