Hehehehe some newcastle action lol
http://www.fattass.dsl.pipex.com/stuff/3jig.JPG
Forgot to mention that is under my R507 prom the Gt is good but doesnt take the heat away as well as the 507
i can only reach 2.7ghz stable with this setting. is it the ram that is stopping me? i was thinking about rma the ram and go for the gskill pc4400 hoping to go higher than this. any suggestions from the experts? btw running the ram with ddr booster at 3.15 volts.
System Is:
CPU: AMD Athlon 64 3200+ @ 2700 ( Water Cooled )
Mobo: MSI K8N Neo2 Platinum BIOS 1.51 beta
RAM: 1024 MB OCZ PC3700 EL Gold Rev.3 (2.5-3-3-8-1T) @ 3.15V
Video: ATI 9800 Radeon PRO @ 450/730 (Water Cooled)
HDD1: 36.7 GB WD Raptor, 10000 RPM SATA
HDD2: 300 GB Maxtor DiamondMax 10, 7200 RPM SATA
PSU: Aspire 500W
BIOS Settings:
Memory Menu --> 1:1 Auto, 1T, 2.5, 3, 8, 3
Cell Menu -->
High Performance = Manual
Aggressive Timing = Disabled
NV/ATI Speed Up = Disabled
DRAM Signal Strength = Normal
Spread Spectrum = Disabled
Cool N Quiet = Disabled
HTT = 3x
Multiplier = 10x
FSB = 270
AGP = 66
VCore = 1.6V
VDIMM = 2.85V
AGP Voltage = 1.60V
http://www.xtremesystems.org/forums/...id=21554&stc=1
|Oc|REvO_HsArC i've the same 3200+ can you give me results about your overclock?
My winnie 3200+ doing 2826mhz @ 1.584V (boxed heatsink with 80mm 4500RPM Fan) PiFast stable Link
I hope ASUS makes a bios that can give me 1.65V and when I have my XP-120 I will try to brake the MHZ record on air :rolleyes:
pretty good timings 4 such a good FSB 270+mhz? R u running a ratio?Quote:
Originally Posted by Cyrus The Virus
Crazy Video Card OC as well....
hes using the 3:2 divider which you could clearly see in clockgen in his pic
Just did some playing with my new Neo2 and week 47 3200+ winnie. Can't wait for some new cooling and some decent ram that doesnt max out at 225fsb 3-3-3-8 :(
***Quote:
Originally Posted by Pimp!
It isn't BSQuote:
Originally Posted by Wingless
My stepping:
ADA3200DIK4BI
CBBHD 0447UPCW
1158317L0072
I will make a new screenshot and let it verify:
http://users.pandora.be/CyrusTheViru...1M%2033Sec.JPG
Checked
Looks like my last PM to you didn't help.Quote:
Anymore of this kind of bashing posts will results in a 3 day vacation.
Consider yourself warned.
Check your PM.
Yo iv looked through a few pages and am interested in any week 46 users experience, have a 46 coming 2moro (3200)
dont really have the time to sift through 10 pages of recent posts :)
K8N NEO 2
3200 Winnie
2x512 G. Skill PC4400
01 Link
http://home.insightbb.com/~myglock19/Bench.JPG
Originally Posted by glock19owner
your score should be a 30s spi with just a little software-mem tweaking
nice oc!
Your SuperPI 1M is 33 because the memory isn't 1:1. I'm at 2.6Ghz with memory @ 1:1 and I get SuperPI 1M or 32. I dont think he's bs - performance seems about right using those settings. Wish I could get 2.8 Ghz tho :)Quote:
I can't overclock cpu when mem is 1:1, my memory sucks in Speeds (except the timings) friday I am going to test some other memory (don't what type it is) And if that doesn't helps I'm buying G.SKill 4400Quote:
Originally Posted by dnottis
thank you...I havent even started tweaking anything really...still finding the sweet spot on the CPU...the G. SKill memory is what really helped...gotta love ram that does 8-4-4-2.5 @300FSB at 1:1 though...and my goal is to hopefully break 29...I know this is a long shot...but I think this setup has a very good chance when I really start tweaking :)Quote:
Originally Posted by esdee
New record for me 3200+ @2951Mhz @1.584V (Screenshot Stable ;) )
Air cooled (box sink + 4500 RPM Fan)
Link Screenshot
That is indeed very impressive.
What speed can you that baby stable?
max stable was 2826 Mhz, the only problem is that I'm missing that Vcore :mad:
Maybe an future bios update will help.
I'd be glad with 2826 Mhz though. :D
No I want more :p: But is it possible with new bios ?Quote:
Originally Posted by Jupiler
Someone thold me that the Winchesters have 0.1V undervolt so If I put de Vcore on 1.65V (ASUS A8N-SLI) then is the real Vcore 1.55V. Is this true (I hope not) ?
Hehe, newer 0441.. spmw I think..
a lot nicer with less voltage :P
http://tsukagi.net/benches/2700.jpg
Finally got my 3000+ into a board. Getting 2.5ghz at 1.65vcore. Sad that its so weak, getting 34second 1m.
Ive gone further with my 3000, 12v rail looks dodgy at 11.85 and reboots when connecting LAN is stopping me from going higher for now
