nice score :toast:Quote:
Originally posted by hipro5
Ooooopppppsssss........ Look who's first(for the time been) at Pi-fast........:toast: :banana: :D
FINALLY with Cas 2-5-2-2 .......
http://www.pctech.gr/hipro5/photos/P..._48.35_png.png
hipro u can use ur P4@4.2 with other bench like cpumark, sandra cpu (HP enabled) ...?
Thanks guys....... :toast:
I can use it for almost EVERYTHING at that speed EXCEPT S-Sandra Arithmetic with th HT enabled......I can do this only at this frequency and a litlle bit more than this.......;)
http://www.pctech.gr/hipro5/photos/P...c_4144_png.png
P42.8C@4097MHz Corsair XMS3500 4:5 2-2-2-5
http://clarisseau.homestead.com/file...us-pifast-.gif
thx ;)Quote:
@hipro5 wich Ram you use zo get 276FSB?!? An whith wich Bandwith?!?
ThX Estide
That's one great result Hipro5! Have been wondering when the bandwidth king would really enter the Canterwood scene. ;)Quote:
As for memory bandwidth.. can we expect some results rivalling that of Maccis?
Would love to see some buffered 7000+ and unbuffered 4000+ scores!
Anyways, keep up the great work Hipro5! :toast:
I use 2 x 256Mb Kingston Value Ram DDR400(PC3200)with Winbond BH-5 chips onboard at 3.05-07 Vmem with(now) Cas 2-2-2-5........The Bandwidth is about 6200MB/s in S-Sandra.......Quote:
ThX Estide
Thanks man...... :toast:Quote:
As for Memory Bandwidth benchies......I'm not interesteed for the time been.....Perhaps later on I'll get a P4 2.4GHz and try it....... ;)
That's COOOOLLLLL Petrus with the P4 2.8GHz.......Good Mem bandwidth as well I think....... ;) :toast:Quote:
Thx hipro5
I will get the kingston 2700 with bh6 chips... I hope that these chips will go higher then my Twinmos Winbond bh5....
CyA
Ok I understand. :)Quote:
And as you say, you will need a nice 2.4C to get those results. But I'm not the one to complain about a 48.35 run at pifast... :D
Petrus: That's some great score you got there man! Now go and break that 49 sec barrier :toast:
IF you feed them with Vmem,they will "rock".......Try to find "W248" or "W251" production date.....This is written below the Winbond logo....... ;)Quote:
Thx hipro5
CyA
Done some benches...
Dual Channel 2-6-2-2
http://213.51.192.130/2464mhz224mhz.jpg
I'm very happy that I find Kingston Bh6 in Germany so to become a "stepping" is too difficult... :( maybe I have great luck and I catch some W248 :) but my luck is'nt very high in the last time :(
But If the Kingston wouldn't "rock" *g* I will test the V-Data 2700 ;) :)
have a good day
Estide
As requested, making this excellent thread sticky:)
Randi:D
Getting a litle better :) I think my Corsairs are maximized as my 3.3 line is crap: 3.09v under load :brick:
http://clarisseau.homestead.com/file...ifast48sec.gif
Oooooopppppsssss........(again) Look who has "broke" the 48sec barrier........ :D :banana:
http://www.pctech.gr/hipro5/photos/P..._47.96_png.png
good job as usualQuote:
Hipro5....ownage man! I love it!
That's just plain mean, Petrus was about to catch up and then you go and do this... :DQuote:
What have you changed since your 48.35 sec score? The CPU speed is lower now so I guess something else has been done. :)
Thanks guys....... :D :toast:
I've changed the .......Memory modules......Now I'm with AGAIN 2 x 256Mb Kingston Value Ram DDR400(PC3200).....BUT with the CH-5 chips on board......I think that they are faster(overal in read - write)) than the BH-5 ones but they need burn-in to go BETTER......I'm still "burning-in" them........
Awesome performance, hipro5. As usual :toast:
Here's my score : 50.14 sec
2.8C at 3994Mhz, P4C800
Thanks Jupiler..... :toast:Quote:
What's holding you back and can't bench higher???.....
CPU I guess.Quote:
Raised the FSB by 1 Mhz and voltage by 0.25V (1.80 to 1.825V) but as soon as I started Pifast, the system rebooted.
The P4C800 overvolts like crazy and I don't wanna kill the cpu.
Seems like 4Ghz is a magic barrier that this sucker can't/won't pass. :mad:
35sec in SuperPi, BTW ;)
