Originally Posted by Activate: AMD
Yeah, youre probably right, mines a bit different, mine goes Pump, rad, cpu, gpu, through T, to pump
http://modsbg.com/gallery/thumbnails.php?album=25
That's mine! :)
Here in Bulgaria I couldn't find green UV liquid addition for the water, so I bought green hose /it even wasn't enought, so there is still one old piece clear hose, that isn't very clear, becouse of it's age :D/ The water blocks are from the Asetek Whater Chill WC Kit, all brought from USA. The pump is Hydor L35 /1700l per hour/ and the heatercore is from old russian car - bought for 10 lewa /about 6$/. It's pure cooper and handles the cooling very well!
Some pics of my old water block:
http://modsbg.com/gallery/displayima...?album=3&pos=0
http://modsbg.com/gallery/displayima...?album=3&pos=1
here is mine, in a case and not in a case :p:
this is my selfmade case:
http://img167.imageshack.us/img167/8168/case22zp.jpg
my tank(with a minijet600 pump and an handmade staff to attack the tank to the base of my case):
http://img167.imageshack.us/img167/9908/vasca9nj.jpg
my radiator(AirFreezer100 from ybris-cooling):
http://img167.imageshack.us/img167/2992/rad7zb.jpg
and my (one of mine)selfmade waterblock:
http://img77.echo.cx/img77/3397/wb12kb.jpg
nice home-made case and waterblocks there, Gioz :toast:
What temps do u get with that?
34C° on cpu in full load with 25C° air/ambient temp
(winter temp :D)
38-39C° on cpu in full load with 30C°air/ambient temp(summer temp)
daaamn nice temps man :toast:
I need to find my cam so i can post some pics of mine..
amd ath 64 3500+ gigabyte k8nxp-sli mobo raptor 10krpm 74 gb hdd 1 gb corsair xms twin pack memory ultra X connect 500 watt power supply dual layer liteon cd rom TT shark case =]
My rig. all housed in a nice u2-ufo :)
http://i7.photobucket.com/albums/y26...i/DSCF0134.jpg
http://i7.photobucket.com/albums/y26...2/DSCF0244.jpg
At the moment one big single loop,
hpps(12v 1048),hpps(12v 1048),hpps(12v 1048),bip dual, cpu (xx-flow), gfx 1, bip single, gfx2, 120.3, 120.1 , hd 1 , hd 2, hd 3, res.
soon to be tripple loops ;)
Gfx loop,
hpps(12v 1048), bip dual, gfx 1, bip single, gfx2, headertank
hd loop,
hpps(12v 1048), hd 1, hd 2, hd 3, 120.1, headertank
cpu loop
12v d5, 120.3, swiftech storm, res (fass - o - matic)
I like water :woot:
omg, that setup is really nice :eek:
Very nice shroud there :toast:
Usama aka Ferrari Freak
Thats alot of good moding work! Kabi, pump and shroud! :toast:Quote:
Originally Posted by mad mikee
/Thomas
Do you like the U2 UFO? I am pleased with it! When I get the WCing in, I will post some pictures.Quote:
Originally Posted by Sc4mpi
Later
Yan
<img src="http://wookie.hipsterdoofus.com/Done_Case3.jpg">
slavic1705
What did you do to put your loop that red?
clean and almost no angles (unless I am not seeing the tee to the right of the pump correctly)?
Thanks for the replys.
To answer your questions:
Turok: I used some Water Wetter for anti-corrosion etc. however it turned the water pink so I put some red food coloring in it. :D It turned the tubes red.
Mikee: The item right of the was my homemade reservoir but I had to turn the case side ways to fill the system. Needless to say I don't use it anymore, I don't really need it.
Here are some more pics:
<img src="http://wookie.hipsterdoofus.com/res.JPG"><P>
<img src="http://wookie.hipsterdoofus.com/back.JPG"><P>
<img src="http://wookie.hipsterdoofus.com/blocks.JPG">
hi,
al very cool en nice meshed cases!!
Hopefully I will have an watercooling setup one day.
probally Thermaltake Bigwater or a second hand.
@Activate: AMD: were did all the cables goe mate?! :D
you should see my current case.. you'll become depressive
xyus
Originally Posted by Xyus89
run :slapass:
:p:
I redid mine, after getting some advise from Maxxx (thx buddy).
Tubing from res to pump was way to long, which annoyed me.
That's why I removed the floppy bay from my PC75 and placed the pump above the HD cage.
Gives me some more space at the bottom and looks cleaner this way.
Im thinking about moving this whole setup to my CM Stacker, which would give me even more room to work in.
This is how is was this morning :
http://users.skynet.be/MetalHead/case/case1.jpg
And now :
http://users.skynet.be/MetalHead/case/case2.jpg
http://users.skynet.be/MetalHead/case/case3.jpg
well mines lame compared to those loverly monsters but hey i got water in there so heres my pic
my pc is composed by:
DFI panparty 939 ultra-d nf4
amd64 venice 3200+
2*256 vitesta 566 TCCD
tagan 480watt
http://img189.imageshack.us/img189/1...50078le.th.jpg
http://img189.imageshack.us/img189/1...50062ut.th.jpg
http://img177.imageshack.us/img177/5...50080ua.th.jpg
have you any tips?
thanks
Nice setup mate! :toast:Quote:
Originally Posted by Jupiler
I removed all my angles today.
http://funkflix.de/pics/wakune.jpg
http://funkflix.de/pics/wakune2.jpg
