Mhm, i will check this when i'm at home...
Another weird thing is the liquid of the watercooling system. It's getting fewer and fewer, but without leaking somewhere. At least i could nothing detect...
ok so whats the best way to unsolder these resistor for the ocp mod, im not new to vmods but ive never had to remove things before...
and a 3k resitor would be ok for the vdroop right? i already have a bunch of 3k's for the ocp mod so as long as i do the vcore mod as well i wont have problem correct?
and also, where tthe heck can i get trimmers >10k locally?? radioshack doesnt have any over 10k and i dont have a CC at the moment...
oh and also, i saw a few pages back people were discussing effectivness of more vdd, going from 1.7 on vdd to 1.9 got me from 250 to 257 and now my ram is limiting hence me modding my board heh...
the stock nb cooler on my mobo when i took it off it was only touchingthe NB on two corners (ahh!) so i lapped it to crap and i put a 60mm fan on it is that enough cooling to experiment with raising VDD or should i just forget about that mod?
thanks everyone :toast:
@Esox (Hecht :D !?)
Weird thing with your cooling fluid!!! :confused: Dunno where it could go...
@Revv23
I take two solder irons with a very fine tip heating up both ends of the smd at the same time, this way you don't damage anything. Soldering the new one there is the same procedure, but often it IS harder to do ;)
vdroop you can compensate with the vcore mod, that's true. :D
Vdd is recommendable by me, but that's me ;) I use up to 2.2V, and it got me more stability.
thanks SAE, i have an old P3 mobo to try that out on, just need to get anoter soldering iron and practice a while.
now all i need to do is find a place to buy VR's locally...
NP. :)
VRs should be available in several variants... from 10ohm up to 100Mohm or so... I don't get it why you cannot get a hold of them :confused:
Try to get multiturn cermet pots, 25 turns should be fine.
most i can get that i know of is radio shack which maxes out at 15 turns and 10k... :(
im looking in phone book now for locall shop though so im praying
Yeah, that's what i did before! Wanna go fishing...? :D :DQuote:
Originally Posted by SAE
i did the old L12 wire trick and i didnt really get any better results. i cant decide iof its my ram or cpu holding me back now. i get 260 and stable and can pass memtest86 at 266 at 9.0 multi but when i boot to windows even at 2.0v aand 3.3vdimm it just locks up. If i bump the multi at 260fsb from 9 to 10 i get like 5000 errors compared to 0 at 260x9....what do you think? or is it my chipset? it loves voltage and im only giving it 1.9 ATM....
@ Revv23
I hold thumbs for ya.
@ Esox
I like fishing, but over the last years I have not been fishing anymore :(
@Stealth
Could be your vdd, but not very likely. Maybe your ram ics are heating up to intensely.
Try swapping ram banks too. But a vdd mod may help though.
@ SAE
I also stopped it last year... :rolleyes:
Yeah. Too bad, but sometimes I miss it. For me it's already longer than one year.Quote:
Originally Posted by Esox
No.1 Superpi 1M Athlon XP: 30s @12.5x265MHz 11-2-2-2-2.0 w/DFI Lanparty B
maaannn... everytime i see that I drool.
:lol:Quote:
Originally Posted by FlyingHamster
Good times that was ;)
HOLY F*CK! how did you get that?!? thats 3.3g's on a AMD!Quote:
^with a mach 2 at -63c thats how hehe
Alotta mods and stuff, cool temps (during a summer night though ;) ) and luck :D
so the cooler you go the more you can prolly get outta a proc?Quote:
thats just crazy man...i cant even hit 260x9.5 stabily and i have bh-6 2500m and 20c watter cooling....
It also depends on your cpu. If it's not capable, it won't get more capable with lower temps in most cases. Older cpus just cannot clock as high, many newer ones also cannot. So the die quality is an important factor, too.Quote:
wanna sell me yours? :CTF:
Where are you? I cannot see you told me a location of yours ;)Quote:
In early 2005 I'll definitely go Socket939, so that my system will be for sale :D
oh im in US..... how much you thinking for mobo, proc, and ram?Quote:
EDIT: wow i just figured out that if you measure for vcore on that one choke that someone said you can measure from (lemme know if you dont know which im talking about) you get a MUCH more acurate reading. on the mosfet leag it would be atleast +/- .5 with the choke its right on the money and doesnt droop at all!
The choke is the same you attach the vdroop to... :DQuote:
I dunno what I can get for my board and proc.... my ram is not for sale, I am eager to test it with my new system ;) (I will maybe get me some VX though - 1GB is a must-have for newer games to get my 1600x1200 res perfectly - reloading textures and sounds at 1600 in HL² suxx)
can you just solder the vdroop to the bottom of the chokes leg where it goes into the mobo as it it soldered there anyways? then i wount need a solder pad... what size fixed would you recammend?Quote:
I soldered the wire to the bottom of the leg :) But it's hard to do, for me it just did not wanna stick first. I needed some time to get it right, so don't be impatient ;)Quote:
I'd recommend a fixed 4.75k as I use.
3.54 vdimm to get 264 on rams SAE?
cause im running 258 with 3.3v and im inches away from getting a CC just so i can order these VR's...
