Hi.
How important for MCP35X2 pump the MCP35X2 Heat Sink? If i use Maelstrom 5 1/4" Dual Bay Reservoir with pre-installed dual or single PWM controlled MCP35X pumps, I will need a heatsink?
Hi.
Hey there
the optional heatsink will help dumping some of the heat coming from the pump but it is not required.
If you choose to use it with Maelstrom though, note that it will make a third 5-1/4" bay unusable for a drive.
Fans looking slim along with the compressions, not so much digging the cpu block though, really unaesthetic imo! , Any tests been done with the fans compared to the typhoons?
well 2012 were very interesting. a lot of new candy from Swiftech.
what about 2013?
I miss shiny chrome of Apogee as well!
http://img834.imageshack.us/img834/9...ttingsx800.jpg
Just ordered my Maelstrom dual pump kit, can't wait to get it :D
Purchased a 7970 Komodo, Apogee Drive II, and compression fittings. Last bits should arrive tomorrow and hopefully get me started on my first loop. I m integrating the whole system into a large L-shaped desk that I have for the time being. Ill probably build a new desk in the near future and make it around the PC. Pics soon.
