Just some minute test
http://img842.imageshack.us/img842/2498/immagineww.png
looks like 50% load on the gpu.
try again with unigine heaven benchmark with 1000 core. my guess is, you wont pass.
my EVGA 580's on SLI open case dont go above 60C with a high ambient temp of 27C and its using 77% of each on BF3 maxed out 1920x1080, i just have a custom fan profile and a fan blowing to them
im using this
http://img600.imageshack.us/img600/9392/p1100587r.jpg
http://img845.imageshack.us/img845/2213/gpuzu.jpg
my custom fan profile
http://img37.imageshack.us/img37/686/fann.jpg
http://img718.imageshack.us/img718/8...7224953612.jpg
Uploaded with ImageShack.us
Hi Guys
I have the MSI N580GTX Twin Frozr II/OC card. Great card but i've just have a few issues.
First off, my card gets very hot when playing BF3. My card reaches 92 Celsius easy with fan ramped to 85%
Def clocks is Core 800 and Mem 2048. GPU Voltage is 1025.
I see my cards fan speed only goes up to 85% in MSI Afterburner. Can anyone else with this card confirm?
Link to card:
http://www.msi.com/pic/product/five_...0114144115.jpg
Ja, i wish i had a block for this card. It gets frikken hot!.
I saved my Bios using GPU-Z. I tried using Nibitor to save bios but it doesn't detect it.
I tried to edit the bios but can't change any sliders?
What app are you guys using to edit bios.
After you saved the bios with GPU-Z you have to change the extension from BIN to ROM. After you open the bios with Nibitor you go to tools to change values on clocks and voltages.
You can read this: http://www.overclock.net/t/989627/fe...gtx-4-5-series to better understand how it works.
hi guys,
lost my original CUII Bios. can anyone send to me the orig. rom pls ?
tia
thx mate :D
Nibitor doesn't seem to read my BIOS correctly.
Need to go into fermi clocks and fermi voltages area. They are domains not voltage settings like old school cards.
