What you guys think, should i buy MIVE or should i wait Z68-based high-end mobo?
Got great deal from MIVE and still have B2-version P8P67 Deluxe so it will be easy chance.. or not?
YoooH > my choise for my setup, but me novice . . .
CPU SPREAD SPECTRUM > disabled
Vcore PWM mode > Extreme
internal PLL overvoltage > enable
and C3 + C6 > disabled
Dominator gt 2000 c8? I had two kits, one of them could run 2260MHz c8 with 1.65v, but both of them couldn't run 2133mhz on 9-9-9. GTX2 have no problems, running 2133MHz 7-7-6 @ 1.65v.
both sets of my Dominator GT 2000 c8, and a set of STT 2200c8 both did not work well with any of my P67 boards, but the GSkill Ripjaw X 2133 8-9-8 kit is killer on sandy bridge. I have been wondering what the higher bin is on the GSkill Ripjaw X line, there is two 2133 kits one 7-10-7 and the other 8-9-8 with the latter being priced about $10 higher and on the 2200 kits there is a 7-10-10 and a 9-9-9 kit with the later being priced higher as well. The cas 7 kits are black while the cas8/9 kits are blue, other than that I have no idea what the better kit is.
On the GSkill website they have a 2300 kit that is rated at 7-10-10 as well which makes me think that the c7 sticks are the higher bin even though they are cheaper than the c8/9 sticks, but I really have no idea as they both seem to clock pretty similar
Bios code seems not optimised on the ahum lower end boards with Hypers... Everything works fine with the ES CPU, put in a retail on eg the Dlx and it goes nuts over 1900ish... this with Hypers... M4E works fine with enough ram voltage ( 1.75ish ) and a good Hyper ram kit
Really hopes Asus steps away and supports all boards with the appropriate bios code...
Is that superpi 32M stable at just 1.65Vdimm ? I can rock 3D easy peasy, but at Superpi 1m it freezes... I'm needing over 1.72 to get even remotely stable...
Ripj X 2133/8-9-8 on my MIVE 2200+ 6-9-6-24 Vdimm 1.82 and Vcsa 1.1ish
Haven't test Ripj X 2200/9-9-9 yet.
Hi to one and all,
I've just got a MIVE and have played around with the *MANY* settings but I cannot fathom out certain parameters. I need further help with things like the "Skew" settings, Digi+VRM/POWER and Turbo power settings. I have been through the ASUS guide on here and on "Hard forum" and checked the pages of this thread. I've checked the Asus website also.
Really annoying.:confused:
Can someone point me to the info on these mysteries. :shrug:
So whats up with Intel's 6gbs contoller?
Looks like my freezing has stopped when there is nothing on controller.
I removed both ssd drives & bam system runs like a top.
Why in older bios do they have control to reduce speed from 6Gbs down to 3Gbs?
Or is it because Intel really never fixed the problem? or just a cheap controller?
Or Asus can't control because of EFI bios?
I find this BS because I pay for something & everything should work.
I need this controller working 100% Asus or Intel fix the problem.
all the fan headers on the m4e are 4 pin pwm...
Can cpu temp be used to control rpm on all the headers or just the header labeled for the CPU?
I've been having some random BSOD's and all of them were while writting or reading from my raid ( that is connected to de SATA 2 ports ). I went to bios and bumped PCH and PCH PLL volts, and I've stop the BSOD's at least for the last 5 days. I think that this might be my B2 giving up :(
I google the BSOD's and they weren't OC related ( they also didn't show in the normal OC BSOD's as 101 124 , etc... ) for what I've found they were memory write reading ore something like that error.
Any words in what were the simptoms for bad B2 chipset ?
