whats your opinion if someone did a 1 hour loop of some game or graphical benchmark and looked at the total power consumption of say killawatt meter? do you think that a spiky consumption would result in horribly skewed total watt-hour consumption? while the display of a meter like that only updates every second or so, does the watt-hour part depend on those low update frequencies?
you take power readings to heart a little more than most sites do, so your opinion is quite valued.
