regarding this high speed nidec servo fans
checked the datasheet of this fans. keep in mind this fans draw a huge amount of current. you wont get that performance for free!
here we go:
5400rpm 1.1A 2.7A
4250rpm 0.6A 1.4A
3000rpm 0.2A 1.0A
the last (red) figure is the startup current! so if anybody is looking at this fans, make sure your fan header, either motherboard or fancontroller, is capable of delivering this amount of current.
compare this to the lower speed versions:
2150rpm 0.1A 0.5A
1850rpm 0.1A 0.4A
that's a totally different league!
on the other hand, i simply don't get why anybody is looking for such a monster? in my watercooling setup i currently run 3 sflex-f fans in a pull config. and this fans are running at about 8V which translates to approx 700rpm! you can argue my setup is not dumping a big amount of heat, but on the other hand my fans are running at 700rpm. also the use of AP15 on my rad will improve things further. but by no way there will be a need for 5400rpm fans at all!
also from looking at various tests, increasing airflow on the rad will decrease temps to a certain amount, but there comes the point where increasing airflow further wont decrease temps any further. at least not noticeably! so i doubt using such a fan on a rad, although pushing a lot of air through it, wont give the expected results in regards of temps!
for aircooling its not that much different. have a look at the reviews of coolers. some reviews show also the decrease of temps in regards to increased fan speed.
while increasing fan speed from below 1000rpm to somewhere near 1600rpm in most situations reduces cpu temps noticeably, increasing fanspeed further past 2000rpm might gain just a few degrees if at all.
dont think the magnitude of noise coming from fans running at this speed is worth it.
i think, finally you will end up running this 5400rpm monster at 1000rpm still at a very high noise level compared to an AP15.
i agree it, would be nice to have a little more power than the AP15 is delivering:
so i think the most interesting models are the 2150rpm and probably the 3000rpm versions with PWM control. unfortunately there is nobody selling them right now - at least i was not able to find somebody.
so i contacted nidec servo, well in fact it'is the european distributor, regarding this fans. had the idea of ordering them and distributing the fans for all of us.
what i got so far:
nidec produces this fans for the oem market, where nidec manufactures the fans at customers specs. usually the order volume is some 10k pieces!
scythe orders the fans from nidec in volumes of 50k units thus gets a decent price.
it should be possible to get this fans in lower quantities (eg. 100 units) and manufactured to the specs requested (PWM ,rpm sensor, speedrating, ...) but the price would be above 50USD still without shipping cost from here to you guys.
delivery time is another issue. as this fans get manufactured per order, there is a delivery time of 12 to 16weeks! this might be the reason why this fans are out of stock for some time now.
this is what i got so far. will get a real quote in about a week. but as said before, i don't think it will be of much use as the price will be far too high and deliverytime too long.
martin, sorry for highjacking your thread with such a long post ...
