My maximum overclock on air is 850/1700/2100 @1.138v, I can't push 20MHz more on Core, Shader and Memory without errors and artifacts! I've heard of someone in my clock range (852MHz on air) getting 900MHz Core at the same voltage switching to water cooling, read 3DGuru's 16 watts less power under water!
>> Right here.
- SystemlordQuote:
Well, the end result is that we are consuming LESS power on water-cooling. Two things are responsible for that, the colder GPU (better conducting) and thus that reference cooler.
Check it out:
Setup IDLE WATTS FULL WATTS
GeForce GTX 480 203 428
GTX 480 Liquid Cooled 201 412
GTX 480 Liquid Cooled 900c|1800s|4400m 215 506
Now granted it's not a lot. But yeah... we are using 16 Watts less all of a sudden. Overclocked obviously changes that and the card starts to consume much more current quickly, but that's also because we overclocked rather insanely and added the voltage tweak.
