Very well done, everyone! :up:
The list should be up to date. :yepp:
^ Keep the list alive
I have been on a break from hardware and overclocking for a while, but picked up an i3-530 today to play with. Using the Gigabyte P55A UD6, Corsair H50, 2x1gb HyperX, XP Pro 32bit.
Batch#3943A849
http://img535.imageshack.us/img535/4830/i3530linx.jpg
Uploaded with ImageShack.us
http://img338.imageshack.us/img338/2...esinxi3530.jpg
can I play too?
New water cooling, I've not had time to optimize setting yet but Linx stable at 4.5ghz
http://i60.photobucket.com/albums/h2...5ghzstable.png
Got mine stable at 4.5GHz! Freakin' finally..
http://valid.canardpc.com/cache/banner/1189233.png
http://img237.imageshack.us/img237/7388/45151328v.jpg
I'm going to work on the memory next. ;)
SimpleTECH,thats a great cpu you have ther.4515 with 1.32v wow,very nice
Thanks radaja.
I've been having an issue with this CPU in the past, couldn't get it above 4.2GHz. For some reason today, I felt like seeing if I could do any better. Keyed in some numbers into the BIOS, tested for stability, and was able to finally get somewhere. :rocker:
I'll update my signature today, here is a thread in the watercooling section aobut the setup
http://www.xtremesystems.org/forums/...d.php?t=251857
That's very nice for such an inexpensive chip! Great vCore, too! :up:
Did XP 32 bit make much of a difference, what do you think?
Hell, yes! :D
Welcome! :cool:
Congrats! I'm sure you can get it higher than that judging by your vCore! :D
Quoted because it looks sexy! :D
I'll bite at your submission, though. Just 2.5GB of RAM used by LinX when you have 6GB installed? Are you using a 32bit OS?
Hi everybody! This is my software development computer.
CPU: i7-980X Batch: 3003B288
Mobo: Asus P6X58D Premium
Ambient: 27c
Feedback on my settings?
RealTempGT was open longer on this run to show max temps
http://img16.imageshack.us/img16/580...ssedcroppe.jpg
Higher Gflops
http://img6.imageshack.us/img6/4723/...ssedcroppe.jpg
@00011011: Maybe a screenshot of all your voltages, (assuming asus has some app that will show this) if not you could simply tell me them?
Also that's quite a computer for no gaming. What sort of work/hobby do you do with it? (if you don't mind)
Another run with the i3-530 today. P55A UD6, Corsair H50, 2x1gb HyperX, XP Pro 32bit
http://img139.imageshack.us/img139/5...inx4620mhz.png
[QUOTE=OC Nub;4395071]Another run with the i3-530 today. P55A UD6, Corsair H50, 2x1gb HyperX, XP Pro 32bit
Great run Tom :up: Congrats
Thank you Sergio.
q9650@4500MHz(9x500) 1.45V LinX Stable
http://img99.imageshack.us/img99/557...xstable.th.jpg
Q9650@4.5GHz (9x500) 1.45V watercooled by EK Supreme HF PA120.3 DDC3.25 XSPC Res Top 6xPanaflo FBA12G12H|ASUS P5E X38 @ Rampage|2x2GB OCZ Blade 1200@1200MHz PL7|Sapphire HD4870X2 832/1000 watercooled by DD|CM RP M1000
Cool! Finally got my watercooling system in check....Swiftech Apogee XT Ultra Extreme is awesome!:D
http://i572.photobucket.com/albums/s...m/Finished.jpg
Intel I7 980X Batch 3003B475
I just noticed this when someone pm'd me in the forum and asked me about my QPI voltage. When I had my 920 c0 then 920 D0 my QPI was 1.50v(on Air), but since I watercooled my system and the QPI/RAM controller on the R2E it dropped down to 1.20v(Lowest on this board)! Thats 12Gig at 1866 at cas 8. Although I've never had a problem running 12 Gig stable with this board(Been running it over a year now), Its an oversight that I never noticed till now. Enzotech's QPI/Dram Waterblock makes a big difference. Hope this helps someone. fyi.:eek:
http://i572.photobucket.com/albums/s...ePicSmall1.jpg
http://i572.photobucket.com/albums/s...ilBabecase.jpg
I will work on that this weekend.
I picked up another 920 a while back for 179.00 at MicroCenter. Finally got around to installing it. I think I can get vcore below 1.4v with a little tweaking.
Batch#3937B785 X58A-UD7, 3x2gb DominatorGT, water cooling.
http://img175.imageshack.us/img175/1...045ghzlinx.png
I'm not quite there yet, (Max memory stable that is) but getting closer. Since I don't have much of a clue yet with overclocking this high, I just plugged in a bunch of numbers and went for it. I'm going to try again tomorrow.
http://i39.photobucket.com/albums/e1...0a_cropped.jpg
