http://i417.photobucket.com/albums/p...n/IMG_0146.jpg
http://i417.photobucket.com/albums/p...n/IMG_0147.jpg
http://www.abload.de/img/img_5458v33z.jpg
http://www.abload.de/img/img_546885pf.jpg
http://www.abload.de/img/img_5498tunp.jpg
http://www.abload.de/img/img_37102uc7.jpg
http://www.abload.de/img/img_5488kl8b0.jpg
http://www.abload.de/img/img_388257ro.jpg
http://www.abload.de/img/img_3869kw63.jpg
http://www.abload.de/img/img_2612lvvz.jpg
http://www.abload.de/img/img_2636xksg.jpg
http://www.abload.de/img/img_5560k6js8.jpg
http://www.abload.de/img/img_5551jc2a.jpg
http://www.abload.de/img/img_5550adcp.jpg
http://www.abload.de/img/img_5528kafae.jpg
http://www.abload.de/img/img_5530p54z.jpg
Prototype:
http://www.abload.de/img/img_5601868k.jpg
You can connect it directly to the mainboard.
bundy, What's the FPI on those Magicool's? P-PC's added them to their site last Friday and I've been using all my spare time looking ever since trying to get a verified FPI on them with no luck.
Bundymania what prototype is that? Flow meter?
You are the master of watercooling reviews hahaha:p
@Waterlogged: I have no info about that, feel free to contact the MC guys
http://www.magicool.biz/Magicool/Contact%20Us.html
@Raiden: Yes, itīs a flowrate indicator, which can be connected both at the mainboard or aquaero
http://www.youtube.com/watch?v=cpVLSEYyRd4
Sooo, I take it you don't have the one you did the review on anymore? :down: :shakes:
Doesn't matter now anyway, read some things that Magicool has some QA problems. . .like the rads leak after you've used them for a while. :eek: NO WANT!!!
Might I suggest that for future reviews, you include FPI count. . .it's one of those little things that make a "meh" review worth reading.
This problem is only for the elegant series ;)
Many peoples in my country are using these cheaps rads (I used it 2 years), and nobody had a problem, just a few peoples with the plexis elegants series !
The 140.X magicools are realy close of the SR-1 series with a low airflow.
Correct, those Magicool Rads are ok and cheap, maybe waterlogged knows only the elegant series, or he just searches for something he can criticize :)
http://www.hardwareluxx.de/community...us-623565.html
There are 4 or 5 Magicools e.g. Rads made by Eastar tested.
The dissapointing part is that according to I believe hesmelaugh (?) the Elegant is one of the best performing rads on low RPM, which means only the actual good performer of Magicool is also a leaky performer :(. I'm not saying the others are bad, but for that price I don't expect much to be honest ^^.
I've never used a Magicool rad and there is very little info of any substance available on them around here. I saw this and got a bit discouraged. I don't have a whole lot of time to do in depth searches and when something like that pops up in the first result on Google, it tells me I should look elsewhere for my parts. After the 2 of you tell me it's mostly the Elegant series, I may reconsider. Thank you both.:up:
