CT, here's the deal on this card: $45+shipping. 7 in stock (12-12-2010). No bracket, and description claims it's LSI SAS9220-8i, which does not exist? Might pick one up anyway just for testing...
$75+shipping with the bracket. 8 in stock (12-12-2010).
EDIT: It's actually 9211-8i, not 9240...
And if it's sounds too good to be true... Some folks report no-boot issue similar to Dell PERCs. Will do a litlle bit research.Quote:
The ServeRAID M1015 SAS/SATA Controller has the following specifications:
* Eight internal 6 Gbps SAS/SATA ports
* Supports SAS and SATA drives (but not in the same RAID volume)
* Two Mini-SAS internal connectors (SFF-8087)
* 6 Gbps throughput per port
* LSI SAS2008 6 Gbps RAID on Chip (ROC) controller
* x8 PCI Express 2.0 host interface
* Supports RAID levels 0, 1, 10 (RAID levels 5 and 50 with optional ServeRAID M1000 Series Advanced Feature Key)
* Connects to up to 32 SAS or SATA drives
* Supports up to 16 logical volumes
* Supports LUN sizes up to 64 TB
* Configurable stripe size up to 64 KB
* Compliant with Disk Data Format (DDF) configuration on disk (COD)
* S.M.A.R.T. support
