When testing the chip of Blind a couple of weeks ago I could hit 240+ easy with 21x multiplier, so the board's capable of doing more than the low 230MHz. At 23x all three chips maxed out completely at around 233MHz, suicide, and 228MHz benchable.
I have a couple of links to scores:
- Blind's 950: pifast at 228MHz BCLK, 1100+ memory
- Gamer's 3540: pifast at 229MHz BCLK, 1100+ memory
- My 950: pifast at 232MHz, 929MHz memory
Max suicide is about 233MHz BCLK. Don't think I've ever seen 234MHz with the 23x multiplier on this board.
Btw, regarding Blades: only issues I've seen so far I already mentioned in PM. First two results are with the Blades and we had no issues running them. Blind had the same problems I already mentioned after this LN2 session; I already tested the kit on other boards and the kit is fully functional. Btw, I can actually get the blades running; all I have to do is manually adjust the timings/voltage with another memory kit, shut down and change to blades. As long as I don't clear the CMOS it runs just fine at 1150MHz CL8.
