Loosen your ram 4-4-4- is too tight for now ,,
phenom likes 5-5-5-15 or higher for high freqencies. or 4-4-4-12 for using low freqencis 400/533 under 800mhz total..The biggest thing that will hold you back is tight timing and trying to exceed your ram clocks. This is why you set those two variables low when clocking the CPU higher(High CPU multi try with 800 then 667 then 533.. Sometimes the ram multi needs to be lowered when using high CPU multi..
You can lower the timing back down after you find that CPU sweet multi. Keep NB around 2000mhz for now and try ganged mode with auto timing for starters while manually using 2T. What ever Ram divider you want.. Set Ram to Maxclocks or manual but keep the timing parimetes on Auto and use 2T setting.
Need more Volt info..
Can you download in instal HWmonitor..post a screen shot for me.
http://www.cpuid.com/hwmonitor.php
Current Vids( and IDLEtemp ? Load temp?
Before we proceed
Im looking up YOUR mobo's features,,Hmmm MOBO,,no sig Hmmmm,, cant give to much info,, if i dont know what mobo to go by.
Prime not be used for extreme amount of time on SB600,unless you can keep the PWM's cool
In particular PWM's found with SB600 MOBO's is affected the most.
Prime will Make the PWM'S heat up alot with even moderate volts. Even more so the higher the Volts and the Mobo thus affecting your CPU, Trust me on that.
So if you prime,, watch the PWM temps. A CPU can lose voltage once the PWM's start overheating(core failure ) up and to a certain extent the PWM's can blow(
BIG NOTE:
Ive maxed several Mobos testing 770/780/790/GX/FX SB600/SB750 with Prime and this 9950 @3.4/3.5ghz @ 1.65+volts using 1.55vid for CPU and NBvids and even over 1.65volts...
SB600 is know to cook PWM'S with Prime and 2.6ghz @anyvolts given enuff time..With that said , use Prime sparingly
Priming 8hours will give my 79-T a pretty decent heat stroke @3.5ghz.
Even though My CPU is stable.
P.S. get me screenshot and i can go from there .
