480x8 is OCCT stable with my X3350. That is the same max stable overclock I got with this chip on P5E3 Premium.
No store received the mobo yet in Brazil :(
But I still want to know if the tracers (best batch [double side chips] and pc6400) are having problem with this mobo...anyone?? :p:
I tried with 2 and 4 with no discernible change and I switched pairs as well . Should I be disabling load line calibration ?
What voltage is set for Vcore ? how much Vcore do you need for 3.6Ghz ? Normally with some tweaking think 470ish could be possible but could well be your CPU does need excessive voltage to get that high.. or some nice GTL tweaking...
R@ptor
My mate has got 2x1gb 6400 Tracer and no problems.Anyway not all double-sided Tracers 6400 were D9GMH chips,only some of them.About year ago Crucial stopped production of D9GMH/GKX for sure ;)
Now you can get Crucial D9GMH/GKX only on Ebay,or used from users :D
It was the Damn RAID Card. I have an old IDE Hard Drive that I need to use in my system. I couldn't use any of the onboard IDE's because I have 2 IDE DVD Burners. So I installed an PCI RAID Card which supports up to 4 additional IDE drives.
As soon as I disconnected the IDE Drive from the RAID Card - Voila - PC posted and booted up just fine.
Can confirm:
OCZ Platinum Edition 4GB (2X2GB) Dual Channel PC2-8000 1000MHz: Works
I'll get some CPU-Z Screens on stock and attach back here. Will start OC'ing in a day or two.
IDLE temperature was running 39 - 41 (Real Temp) - Does that sound about right?
Thanks!
Did anybody try max. FSB with e7200? ... I have fsb wall at 510fsb on Commando (on air) and with P5QDlx it is 510fsb, too :(... no more with any other settings... to 510fsb it needs only vFSB 1.16V and vNB 1.2V.... Bios 0702...
the kit of memories that you purchased this was here:
http://www.newegg.com/Product/Produc...82E16820227280
Thanks,
Just curious i think someone already asked this. Is the P5Q-dlx wifi any different performance wise than the p5q-dlx
Got a question for the experts :
Is there someone who knows how to mod bios', who can have a look into the P5Q-Pro 0506 bios, and see if the GTL tweaks are hidden, and can be enabled?
I used an AMI bios editor to check the bios, but I don't know if the program can check for any hidden features in a bios.
Ordered one of these this afternoon, tho I won't get to play with it til the w-end.
Hoping for atleast 500mhz stable from my Q9450 since I can run 1mb Super-Pi at 490mhz in my IP35 Pro's.
Considering changing my P5K Premium for the P5Q Deluxe and I'm concerned that I'll lose the use of some sata ports using my 8800gts gpu. Can anyone confirm this ?
my p5Q-d arrives by the end of this week :)
anyone have any issues setting up 8GB of ram with this bad boy?
Some 3D action, system in sig:
http://i29.tinypic.com/6z22dg.jpg
Interested in this board, some of the early reviews suggested the performance could have been better. Has it improved with later bios(s) ?
If 600FSB is ya thing with wolfies yes things have improved, also we are seeing 500FSB quad action... just make sure you flash to 0610 or 0702 bios
