More Juice..More Juice...:up: Then :explode:
updated:up: nice work ppl, i guess gotta prepare for when those new chips come out been real busy lately
let me get in on this
http://service.futuremark.com/compare?3dm06=9150421
3.3ghz, Phenom 9950, 4850X2 2gb @ 700/1180
3DMark Score 17613 3DMarks
SM 2.0 Score 6659 Marks
SM 3.0 Score 9032 Marks
CPU Score 4464 Marks
Ooops sry double post ,,Beer did it.
Im done!
Can add me to the 18000 club:D
http://service.futuremark.com/compare?3dm06=9249738
My best Oc ever
9950(140watt) @ 3550mhz ,,NB2630,,HT2630
AsusM3A79-T
3870x2 @ 945/1089mhz Stock Air
No voltmods!
18044
SM 2.0 .....7092
SM 3.0 .....8744
CPU..........4808
Not bad for a Single 3870x2:D
Grats! wecome to the 18000 point club . Nice run with your 3870x2 :clap:
if that is vista 64 you got 1 hell of a cpu score!
its Vista 32 bit
updated:up:
Something..
http://faior.miumau.net/06mark3.3ghz.JPG
HD4850 @ 680/1080MHz only.. CPU Score is in the area I think. :) THough i get 4600 with 3.1GHz
Your right on... It all depend on how good the Os is set up and ram for Higher Scores..Sometimes tighter timing will up the CPU score a litlle but not Much.4800 is nice @ 3.3ghz
Mr Max i need one more update please:D
I tried for 3.6ghz but CPU wasnt 100% , I have to figure out how to make that Extra 9mhz stable on CPU:rofl:.Chip dont like Low HT/NB @ 267x 13.5
9950 @3591mhz NB2660 HT2660
3870x2 @931//1080mhz.. I lowered it it just in case to pass .. I may be able to get more but am happy with what i have.
http://service.futuremark.com/compare?3dm06=9257981
Thanks gotvoltage, appreciate. :)
My best is this:
http://faior.miumau.net/14k.JPG
Cant do any better with this card though. HD4850 stock cooler.
Hmmm if you like tweaking stuff and have Mx2 on hand,, replace tim on the GPU using the stock ram pads and then use 100% fan.. I can see you getting 760+core with same ram freqency.:D My 4850 was only good to 800/2400 with water cooling and stock Volts..
If you want more with stock cooling change the thermal paste on GPU only. it works.
Yeah ,,i cant keep my hands off nothing:ROTF:.
My 3870x2 on AIR 945mhz//1089mhz both cores MX2 on gpu's ONly:shocked:
Spent about an hour trying a couple different things this weekend and upped my score a little.
9850 @ 3.4GHz
3x 4870 @ 820/1030
3DMark06 - 18,813
nice work ben *updated*
WAS ABLE TO BUMP IT UP A LITTLE LAST NIGHT
http://service.futuremark.com/compare?3dm06=9329881
