Hi, running 0505 bios, dividers 1:2, 1066mhz, 2.2volts...
ChrisC
ChrisC
those of you that are running 1066 mhz on your ram can you post your specs?? maybe i need to mess with my strap option to see if i can get it to work...i can get up to 500 fsb now with 505 but it just doesnt like running ram very high bummer
cuke2u, I have the rest of my parts shipping in soon and it looks like we are gonna have pretty close build specs. think you could post your settings in the long format listed a couple pages back?
@andyr(uk)
Sorry your right i'd read this & assumed it was 0505:DQuote:
M8 that shows up as 0401 in cpuz
Post#107Quote:
Clunk Post#147
Yep, this is 0505, all dividers working and stable so far.
I'm just trying them all again with lower voltage...seems to be working as well
Grrr... Really should have got this board instead of P5E...I was rushed into buying it.
just an update things are going great @ 380fsb and 1140 mhz ram....running some stability tests right now but wow very nice...i love this board...uh oh im gettin the dreaded driver has stopped reasponding again!!! damn it
Just placed my order for a Maximus Formula. :)
Somebody confirms that @505 rectifies vdrop?
That values make now with loadline enabled.
Great news... :up:
divider 4:5 is broken. 5:6 works, 1:1 works, 1:2 works, seems like only 4:5 is broken, not so bad.
Yep Priming as we speak and have been for the last 3 hrs and no droop and 0.01v diff than bios , 1.5 bios = 1.49 in probe and 1.488 in cpuz which is close enough for me
@505
Divider 2:3 ok :up:
http://img91.imageshack.us/img91/8985/1200505ht1.th.jpg
Had mine outside tonight in the uber 3c thats just hit us. Got 4.12Ghz stock cooler. Defo doesn't like Cellshock or Balstix currrently and that was with the 0505 bios. I was half way through Super PI XS 1.50 MOD and it crashed!
http://img.photobucket.com/albums/v6...E/PA175412.jpg
http://img.photobucket.com/albums/v6...E/PA175413.jpg
http://img.photobucket.com/albums/v6...E/PA175414.jpg
Yes thats 4 Raptors in RAID0
wrong link this is the correct one.
http://www.clunk.org.uk/forums/showp...8&postcount=12
pic of all parts ready to be put in new system when my MM order comes in.
http://i241.photobucket.com/albums/f...inter07015.jpg
1 Bestbuy pny sata II Raid controler PCIE 1x
12x ebay 120mm 4 Green LED fans done
9x ebay 120mm biohazard fan grils
2x ebay Danger Watercooled Windows Applique's
2x ebay Danger Overclocking inside Windows Applique's
10ft dangerden 7/16" ID (5/8" OD) Masterkleer General Purpose Clear PVC Tubing
4x dangerden Danger Den High Flow Fittings, Fitting Size: For 1/2" ID Tubing, Thread Type: G 1/4 BSPP
2x Newegg ZALMAN MFC1 Plus-B Black 6 Channel Multi Fan Controller - Retail
1 Newegg SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
8x xpcgear 18in sata II green uv cables
1 performance-pcs.com EK-FCR600 CF Xtreme High Performance Water Block for Radeon HD2900 XT - Acetal
1 motherboardpros.com x38 maximus formula asus mobo
Order waiting on.
1 mountainmods.com U2-UFO Black Powder Coat - Original Top
3x mountainmods.com Nickel Plated Power Switch
1 mountainmods.com Mountain Mods Acrylic Feet (Smoked Grey)
2x mountainmods.com Mountain Mods ALU (Mirror Black Powder Coat) 5-1/4 bay cover
1 mountainmods.com Swiftech - MCR-320 QP
3x mountainmods.com Dual 12 Inch UV Cold Cathode Kit
plus current parts are
sapphire HD2900XT 1gb
Swiftech - MCR-220 QP rad
Swiftech - MCP655 pump
Swiftech - Apogee GT cpu waterblock
Swiftech - MCRES-Micro res
Mushkin HP2-6400 4gb memory
3x Western digital raptors raid 0
2x Western digital RE2 400gb raid 1
2x Western digital Cav 200gb
Pete- Nice! I like your style (4 raptors RAID 0 )~ any more luck w/ it ?
