I'm with you Collin. Done with ewiz. My only second order there and most likely the last.
Yeah...I wouldn't say they're horrible...they just aren't anything close to Newegg's customer service.
-Collin-
too bad newegg cant keep them in stock lol.
they had to cancel my order... OOS... = (
I guess I'm keeping my Quad GT!
newegg has 19 in stock
oh snap I got one. Thanks for the tip!
Hi everyone, i am getting a c2d e6600 soon just like to find out is it worth getting this board over the asus commando/p5be + or gigabyte dq6/ds4 which i have shortlisted? Could any users give some comments?
Thnx for the fast response burningrave. Suggestion noted.
Anyone using 4 x 1GB ram on the P965-S? if so what ram you using etc.
I am using 4x1gb Mushkin redlines pc1000 highest stable so far on this board 490fsb 1:1, they did 522 on my p5b but i need to tweek them on this board.
Mem is set at 2.1 these sticks like to be undervolted. Timings 4-4-4-9. bandwith in much improved over my P5b , but so far I cant run as high.
I havent installed my board yet and I'm not sure which FSB I will use. But i'll do tests at >500fsb
Just nabbed another DFI P965-S from newegg:D
Hey guys, I just got my P965-S today and I was wondering if anyone could point me towards a thread on this forum or a different forum that has a good guide for tweaking the BIOS on this board. This is my first DFI motherboard and, as I expected, all the options are a bit overwhelming. I was wondering if there are any particular options in the BIOS that I should change before I get going (Options that are specific to this board). And what would you guys recommend is the best BIOS so far?
Thanks to anyone who can help me out, really appreciate it.
