I admit to OCing a late week conroe. :fact: others might not ;)
Update to my previous post:
User name: Family man 72
Stability: 9+ hours Prime 25.1
CPU name E6700
OC: 3654 Mhz
Stepping: B2
Week: L628
Code: B112
Vcore: 1.3875V (set from bios)
Cooling: Water
Cooler brand/model: Swiftech Apogee GT
Motherboard: Asus P5W DH Deluxe
Bios Version: 1707
Operating System: XP 32
RAM brand: OCZ
RAM rated speed: PC8500
RAM actual speed: 913
Latency: 4-4-4-12
Username scottk
CPU E6600, L636 A548
OC: 3609, dual P95 instances, blend on core 0, LIPFFT on core 1, 15h 59min
Vcore: 1.6 in BIOS
Cooling: Water
Cooler brand/model: Swiftech Storm Rev. 2, Swiftech MCP655, Thermochill PA120.3, (3) 120mm Scythe SFF21F @ ~75% speed with Sunbeam controller.
Motherboard: Intel Bad Axe 2 rev. 503
Bios Version: 2507
RAM brand: (2) G.SKILL F2-6400PHU1-1GBHZ
RAM rated speed: PC2 6400, DDR2 800
RAM actual speed: DDR 802, 1066 strap, 1:1 ratio
Latency: 4-4-4-12
Comments...
Peak load temp running P95 24.14 with dual instances (blend on core 0, LIPFFT on core 1) is 62C in IDU, with ambient around 80F. I stopped the P95 instances to get the elapsed times in the screenshot (15h, 59min). Should have waited another minute to hit 16h lol.
http://www.forsocal.com/skpc/forumpi...0070511-3a.gif
I don't see entires with higher than priority 1 for Orthos and those are the blend test. This does not stress the cpu enough to consider it a stable o/c.
Imo it should be higher than priority 1, at least 4 and only cpu test. Blend test is too easy.
what does it mean a E6600 with 7639A195 step ? :eek:
Blend is the hardest test to pass. You will find that 90% of people around here will agree with that. I can definitely pass CPU test at higher overclocks than I can on blend. Also, most people use priority 1 because it doesnt seem to make a difference in the speed it finds errors. I can do priority 9 and it will crash at 30 minutes and then do priority 1 and it will crash in a time very close to that.
Huh! :confused: how can blend test be a true test of cpu o/c stability? its a blend test eg. jumping from ram to cpu and back and forth... This thread is about Conroe Overclock Database, in other words the cpu not the ram. To say my Conroe O/C is stable because it passes blend test for X hours is just plain unrealistic. The plot here is the cpu not the ram included.:fact:
Blend test is for system stability.
When I tested out my E6600 a few mos. ago, it could do 3.825 with 1.475v and and passed "small fft" 24+hrs yet it failed blend test in less than 2 hrs. To attain the same clock speed and make it blend test stable, I need to raise vcore to 1.5325 and up the vmch a notch.
You wanna stress out the cpu "only", forget about Orthos small fft, go run TAT instead.
Here is my newest chip from TankGuys. Its AMAZING!
User Name: Babalouj
Stability: Prime 95 blend 18+ hrs.
CPU: E6600
OC: 3608MHz
Stepping: B2
Week: L629
Code: B386
Vcore: 1.34V
Cooling: Water
Cooler brand/model: DTek Fuzion
Motherboard: DFI 965-S Dark
Bios Version: 0424
Operating System: Windows XP Pro
RAM brand: Crucial
RAM rated speed: PC6400
RAM actual speed: 800
Latency: 4-4-4-12 2T
Thats a 29B :eek:
your very lucky to get that week/batch :toast:
A) How do you take a screen shot like those above?
B) How do you post a screen shot?
:shrug:
User Name: largon
Stability: 9hour+ ORTHOS Small FTT
CPU name E6600
OC: 3600MHz
Stepping: 6 B2
Week: L636
Code: A229
Vcore: 1.484V
Cooling: Water
Cooler brand/model: NexXxos XP
Motherboard: GigaByte DS4
Bios Version: F9D
RAM brand: TeamGroup
RAM rated speed: PC5300
Latency: 3-3-3-6
PSU: Seasonic M12 600W 80+
http://www.helsinki.fi/~llounent/ORT...6A229_0305.png
Update:
Stability: 8+ hours Prime 25.1
CPU name E6700
OC: 3704 Mhz
Stepping: B2
Week: L628
Code: B112
Vcore: 1.4125V (set from bios)
Cooling: Water
Bios Version: 1707
RAM brand: OCZ
RAM actual speed: 926
Latency: 4-4-4-12
CPU: Intel Core 2 Duo E6420
Core: 3.579 mHz
Stepping: 6 B2
Week: L647
Code: G476
vCore: 1.52
Cooling: Air
Cooling Brand: TR Ultra-120 & Scythe S-Flex
MB: DFI Infinity P965-S
BIOS: 4/24
OS: XP 32
RAM: G.Skill
Rated: PC2-6400
Actual: DDR2-886
Timings: 4-4-4-10
User Name: MaK2000
Stability: 14+ hrs Orthos
CPU name: E6300
OC: 2975mhz
Stepping: 6 B2
Week: L629
Code: A291
Vcore: 1.3v
Cooling: Air
Cooler brand/model: TT Big Typhoon
Motherboard: Asus P5B, Not Deluxe
Bios Version: 1102
Operating System: XP32
RAM brand: Corsair Dominator
RAM actual speed: 850
Latency: 4-4-4-12
http://i182.photobucket.com/albums/x...iff/Orthos.jpg
hey guys.....
what about 6700 L652B????????
is good for extreme overclock or not???
Ive noticed alot of people have been putting there stepping at B2 6 as reported by CPU-Z but i thought that was just a bug, the stepping info is printed either on the chip or on the retail box. The table on the front page is misleading
EG: my retail box say my full stepping info as L629 B361
so surely my stepping is B3 29. Please correct me if im wrong
