I need help with this board. Can some of you guys post your bios settings with high overclocked 3770ks and 16gb of ram(i have the lv Samsungs).
Why don't use ROG Exchange buddy?...you can search bios profile compatible with your system,dowload and put in use ( check compatibility before )
http://www.firegoon.com/images/1zvyp52.png
( Nobody download my 4300 @ 1.090 Vcore - CPU PLL 1.40 Vcore bios profile...i'm sad! )
Rog Exchange link
http://rog.asus.com/rog-pro/rog-exchange/
WTF is that? Sharing preset bioses? What a mad idea, I'm definitely going to give this a go.
:D
I have this issue with saving my bios. I can change everything in the bios, save a profile, load a profile, load preset values but when i press F10 to save and exit it freeze and after 5-10 sec my pc shut down. If i try again i have the same issue, if i let it boot normally it loads win7 and run everything like it should. Any ideas?
Found a new bios 1502 when i was checking Rog Exchange , but right now the link seems broken http://forums.anandtech.com/showthread.php?t=2151096
any other links for 1502 bios?
Maybe someone can upload it here as soon as the ftp works.
If u check Rog Exchange and Gene V with all cpus there is a 1502 bios. Using 1408 today but is there any better bios before this, maybe recuiers less volt etc ?
1502 Bios that show ROG EXCHANGE is a beta bios and not public at the moment....this link was posted before, is old dated from 2011 and of course don't work
we talk about another 1502 bios file "original"from 2011 and this last one (that you see in rog exchange ) in beta state and not public condition
Any news about test bios 1502?
1604 bios for maximus V gene came out today.
Anyone tried it yet?
do you have any link? I don't see anything on rog page, just only the 1604 V extreme edition
http://rog.asus.com/forum/showthread...untry=&status=
EDIT
here the link for V Gene
http://support.asus.com/Download.asp...-ASUS-1604.zip
I installed, same that last bios, nothing new, I boot 4.0 Ghz same vcores,same temps, same results on AIDA 64...date are 12/21/2012
New bios for VGene users
Version 1802
Description MAXIMUS V GENE BIOS 1802
Optimize BIOS configuration
2013.06.06
https://www.asus.com/ROG_ROG/MAXIMUS...rt_Download_30
Maximus V Gene bios 1802 - 1413 ram Air easily / Avexir MPower Cas11
http://www.firegoon.com/u/sbw8h.jpg
hi guys, which's best bios for Maximus V Gene under LN2? i use 1802 but i have some problem....
I have this board...I water cool the vrms (thanks EK), and I water cool the cpu and memory (thanks XSPC...truly the best bang for the buck and very high quality). That said, I have overclocked the 3570k to 4.7GHZ 24/7 stable and the 3770k I have only tried 4.7GHZ thus far (I just got it) but I got it stable at 1.28 V-core my first try. I have had the board for 6-months now and never had a single issue...it's just stable and easy to over-clock, hell the clear CMOS button is easy to hit as it is mounted on the I/O panel. I like the Gene so much I designed and built a fully modular aluminum case for Micro-ATX since I plan on just getting the latest Gene board whenever I upgrade...the case I built will last forever (1/4-20 aluminum knurled thumb screws are used for mounting everything...with the exception of manufacturer tapped m3 and 6/32 screws for the drives, usb-3 i/o, and psu. Sorry, I'm a little to proud of my case...but I love this board, it's constant Bios updates to improve stability and new CPUs, and overall Asus quality and dedication to overclocking enthusiasts...you get it all with this board...and for only @ $200...Wow!
They just released a 1903 bios to update performance/stability.
http://support.asus.com/download.asp...8FqqcmVLDbZLyx
