It is not, just strange view. :up:
regards
regards
godmod, that was noticeable to me also. :D Could you make a few pictures from the inside, LittleDevil?
Do these SS units make a lot of noise?
Rotary unit is pretty loud, compressor is louder than fan.
NL11F units are quiet, we can say that fan on condensor is louder than compressor. ;)
Regards
Ok, finally after like 3 weeks, Norwegian Toll/customs released this package from LD.
I have been waiting, and waiting..lol
But, it was so worth the wait, the unit described in earlier posts here is simply awesome:D
LD has done a very good job in finetuneing this little SS.
Im goona use it for my Xeons (3060,3070 and X3220 quad)
From what i have tested so far, it seems like i can run my quad easy on 1.65vcore 2 cores, have not tested load on 4 cores yet, only fast wprime.
I have a G0 quad, possible they runs cooler than other not G0 chip.
Because i got good temps, almost too good, so i wanna test with another tempmeter before i give temps here. And run wprime and 3Dmark 06 cputest
Also mine C2D Xeon 3070@1,635vcore was flying under this SS.
Have a pic of a fast suicidescreen 2 hours ago, i was having no problem benching pi, pifast, wprime on 1,635vcore 1 and 2 cores enabled, only a few celcius different from 1-2 cores.
I need test some moore, and find the limit on this SS, so far its looking really good. Im very happy so far.
Thanks LD:cool:
--cheers--
MB used is Asus P5K vcore, vdroop and vdimm modded.
Crucial PC8500 Ballistix@2.4vdimm
ATI pci VGA
Seasonic 700w psu
Benching unit
http://ld-phasechange.com/images/Cupra's_SS/1.jpg
Almost 250W load:
http://ld-phasechange.com/images/Cupra's_SS/2.jpg
Temps on 247W load:
http://ld-phasechange.com/images/Cupra's_SS/3.jpg
Finished:
http://ld-phasechange.com/images/Cupra's_SS/5.jpg
http://ld-phasechange.com/images/Cupra's_SS/6.jpg
Regards
Really nice Norz, we are waiting or more results ;)
Regards
do you run 507 or 402 in those units?
I see you keep pictures of naked men in your workspace. Is that your inspiration for the nice looking units you build?
LOL:D :D , my sistem put that calendar there, i didn't notice it before :ROTF: :ROTF:Quote:
Regards
ales, nothing wrong to have "a thing" for boys as well ;)
but you didn't answer my question, r402 or 507? ^^
@tim: ;)
And gas is R507.
Best Regards
Incredibly nice job Little D.
yea absolutly.. thumbs up for you :up:
another result with ss by LD :
Cpu-z Maxscreen: 5028Mhz at -43,6°C :D
Cpu: Intel Pentium D 915
Mobo: Asus P5WD2-E Premium
Thanks LittleDevil!! :up:
http://wawabob.free.fr/images/o-c/d915/Cpu-z_5028.png
Great job there ;)
Another Single Stage Carbon Edition ;)
http://ld-phasechange.com/images/Aur...#39;s_SS/2.jpg
http://ld-phasechange.com/images/Aur...#39;s_SS/5.jpg
http://ld-phasechange.com/images/Aur...#39;s_SS/6.jpg
http://ld-phasechange.com/images/Aur...#39;s_SS/8.jpg
http://ld-phasechange.com/images/Aur...#39;s_SS/9.jpg
Regards
This one is a true beauty!
Very nice unit, but a bit of a mess around the head's braiding ?? :o
200w load:
http://ld-phasechange.com/images/Aur...39;s_SS/10.jpg
245W load:
http://ld-phasechange.com/images/Aur...39;s_SS/11.jpg
Regards
looks very good
when will you try something new? :p
How long is the capillary tube, which you used in the unit? Which diameter? Which pressures do you have? Static pressure? Refrigerant?
THX
Gas is R507, other specs are TOP secret :DQuote:
THX
Regards
