thx
preparing to braze
http://img230.imageshack.us/img230/3...brazingci7.jpg
thx
preparing to braze
Hot damn your good man, very good. I personally can't find large thick condensers to begin with. :(
Very good looking! I think I'm going to try make some myselft but they'll probably look quite bad.. I will have to make the u-bends.
man, that's an hell of a job to make all those brazings. hope it works fine for you.
thxQuote:
Originally Posted by tim-
2 days ago I make a AIR pressure test
pressure is going 27 bar to 14bar :confused: :confused: :confused:
http://img421.imageshack.us/img421/3804/test1wj4.jpg
whole condenser in water(0 air bubles)
leak in your lineset maybe? it does happen
Don't you have a purging setup? Otherwise that condenser's probably ruined on the inside from the brazing.
@MarioMAster I turn off manifold and compressor
@n00b 0f l337 I brazing without purging
:( Oh no. I suggest reading LukeXE's latest single autocascade build in a case. That condenser will definetly need to be cleaned out somewhat before it can be used.
yeeeeah I found hole :banana:
http://img143.imageshack.us/img143/7346/leaklc4.jpg
So what are u waiting for . Braze it , or search 4 another :p btw must me very painfull work to rebuild those condensers. :)
I agree too much work for me. Condensors are cheap and I think the time to modify one cost more than a new one.Quote:
Originally Posted by Athens[2004]
Nice job though but Ialso suggest to purge, the insides of the condensor must be full of oxidation ready to block your captube.
maybe cheap, but in Poland hard to found 12cm condenser in a good price :(Quote:
Originally Posted by johann
oxidation maybe I rinse cond in vinegar ;)
parts for this condensor cost me about ~12 euro ;)
no vinegar !!! unless you clean it out real good after
acid and oil dont mix, they look like nice condensers though
like I said before, acid will lead to compressor death
it corrodes the winding electrical insulation (very thin clear coat)
big condenser is leak free i used that cond in my autocascade ;)
I bought a another condenser (very cheap :D )
http://img167.imageshack.us/img167/6056/cond1ka8.jpg
this condeser was used in watercooling system :mad:
http://img153.imageshack.us/img153/1932/szlamaw0.jpg
slime of one channel
1,5 hour later
http://img89.imageshack.us/img89/8516/endrr7.jpg
http://img118.imageshack.us/img118/2729/end2ks9.jpg
Man this is desgusting:slobber:Quote:
Originally Posted by Duniek
The reason i like phase change:)
thats is really nice.:toast:
what did you do at the end of the pipe? and how? nice job btw
hey duniek your work is superb dude.. how about a fornt pic of the beauty?
sorry but I don't have this condensor in my house
this is a new one
http://img66.imageshack.us/img66/6817/skr1lg3.jpg
http://img66.imageshack.us/img66/2875/skr2kr9.jpg
http://img66.imageshack.us/img66/5176/skr3pt7.jpg
http://img66.imageshack.us/img66/5062/skr4xf2.jpg
when I have free time I will clean and paint it :)
Nice condensors, how long do you need to make one?
regards
