......Now this is an UNBUFFERED S-Sandra mem bench......
wow... can you get to 2-2-2-5 timings ? or would you need even more vdim voltage ?
The WPCREDID doen't allow me to do so....... :(Quote:
hipro, you are the man.:banana:
you sure ? i'm able to for my p4g8xQuote:
Maybe cos my ram can't afford it over 200MHz???.....Who knows....I'll try it below 200MHz fsb......Quote:
Thanks man....... :toast:Quote:
hipro, you crazy greek ;) j/k
Is there anything you haven't modded on the board yet? :D
Seems like you're always able to push your boards far beyond limits.
Amazing bandwith scores, congrats. :banana:
hipro5 = "the memory bandwith KING" :D
Was kinda hoping you could post some of the pics so I can give them a try.. :D If they are not too difficult..
Wow, um, wow....um.........uh.........hm.........you added caps to the motherboard?:eek:
162 4x turbo :) (only) [no mods at all]
http://kikoguru.supereva.it/img/rimmina.png
Ciao
Thanks Jupiler...... ;) :toast:Quote:
Don't be in a harry...!!!... I'll post them as soon as I lent a digicam from a friend of mine...... ;)Quote:
Yeap I did,as I did to my ABIT one......take a look at ABIT.......Quote:
There you go a little bit more......My CPU just can't handle any more fsb to bench....... ;)
Hipro5, autos einai poli kala.
Very well done:slobber:
im a bit ignorant, but how do those extra caps help? looks interesting...
Thanks.....Geia sou...... :toast:Quote:
They don't work on Overclockability as well as they do on Stability at high frequencies......They "keep" the VCore "alive" at full loads...... ;)Quote:
This is an unbuffered Sandra score of a P4T-E at a mere 156/4x. It is actually more efficient than a P4T533.Quote:
162 4x turbo (only) [no mods at all]
Very interesting, looks like rambus stills wins in unbuffered tests. A better comparison would be to run quake 3 with low detail at 640 / 480 with equal cpu mhz if possible on a ti-4600 or a Radeon 9700. This would be a more real world comparison of memory bandwidth. I never trust sandra, theoretical numbers somehow do not always apply to real world games / apps.
are you sure that you have unchecked the rights things?Quote:
http://www.hwplanet.com/articoli/F@b...002options.gif
http://kikoguru.supereva.it/img/134.png
Ciao
F
r
i
c
k
i
n
a
m
a
z
i
n
g
ok ok ok :slobber:
And on that note I have two questions:Quote:
1) How did you determine the size of the capacitors?
2) Where did you install them? I'm guessing on one of the circuit traces that leads to the DIMM socket?
