Really sorry to hear about the CPU Kingpin...that was one damn fine chip. Hopefully you find lady luck on your side and you come across another beauty to play with. :)
That poor little chip must have had about 100 LN2 baths :D It's probably cracked in half under the skin ...
Regards
Andy
With a new dual gpu kit that will be cake Kris ;)Quote:
Originally Posted by freecableguy
At 4070mhz or so with my current tuning and gpu clocks, I calculated about the max this setup could put out is around 157k. Not gonna happen with my good ES gone Would have been an amazing score for single gpu and dothan.
Did some testing on my last 780ES that was one of the first revision ES's out along with the Japanese from early last year that I still have here. This chip however is fsb limited over 3400mhz (just like Japanese ES's). It can only scale with the 17x. Working on getting it 3d stable over 4100mhz today. I will need 4100-4150mhz using 17x to match the power of the ES that died at 4ghz+ with 15x. This chip is so worked. All of the edges of the die are rounded off smooth. It looks as though it has been sanded lol.
Testing is good so far with it...this chip can take over 1.9v NP:
cpu valid at 4200mhz:
http://pic20.picturetrail.com/VOL256.../143754595.jpg
LOL...chip still shows up on cpuz search HOF as dothan 735 just like it did when they first came out.
http://valid.x86-secret.com/show_oc?id=90777
3dmark 03' cpu testing at 4020mhz with def gtx clocks:
http://pic20.picturetrail.com/VOL256.../143753999.jpg
Some 01' testing def gpu clocks..LOD 3, no multi. proc. tweak or memset used yet:
http://pic20.picturetrail.com/VOL256.../143753995.jpg
You can see the low fsb is handicapping the cpu power as I could easily match those 01 system score with 15x and around 3920mhz on the other chip.
i need to get you a Conroe. ;)
yes...the Darkside is calling me again Kris :shock:Quote:
Your early results with the chips are quite impressive to say the least.
Well just look @ ebay :p:
KP... a true legend... i love to watch this, GL with testing!
So far so good with the fsb locked ES.
I had close to this cpu speed below 2 days ago in 01' on my good ES with 15x and 270+ on the ram before the chip failed. With a little higher card clocks then what I was running today and 270-271 x 15 like I had, 57k or more no doubt about it. 1030+ DL's easy. Still got Kyosen though :)
Pentium M 780ES @ 239x17 7900GTX@ 1031/1094:
http://pic20.picturetrail.com/VOL256.../143919601.jpg
http://service.futuremark.com/compare?2k1=8965434
Chip's got more in it still, I know it.
Originally Posted by k|ngp|n
nice score :)
where was that during your slugfest with hipro a few weeks ago:D
Thanx ex2cib. SLI stuff burned up all my damn time ...but better late than never eh? My timing is just bad. The load temperatures that this score requires is not good for warm and humid weather we have now :(. Prolly should have finished off dothan stuff over a month ago. That nearly 56k score took so much. The new intel kits will be pulling very close to 60k I bet...good times ahead.Quote:
Originally Posted by ex2cib
That is some impressive stuff man. Where do you live where it's hot/humid enough to really affect your inside temps that much?
i know what you mean, 81 here right now, @ 630
can't wait to see the next round of scores with next gen hardware
Like you said,Its better late than never,VinceQuote:
nice work :toast:
Could you tell us the GPU container temperature for this run ?
thanks
Thanx sang. I had the conainer temp around -85c to -90c for these runs. Is team romania still going to put some dothan numbers up at the top? Looking forward to that. Dothan is still very strong chip for single card 01'...despite the new intel offerings.Quote:
Originally Posted by sang
-90 looks awsome Vince. I dont think my Gainward will stand it.
I presume Delta = 0,right ? And how did you solved your previous bugged DL,DH runs ?
Ill try some LIVE 2k1 saturday.
Some nice work their k|ngp|n, you certainly always get your money's worth out of your kit .
Regards
Andy
