http://img50.imageshack.us/img50/974...sdaytl1.th.jpg
just have to vacuum it now, and do a ice run before i insulate.
http://img62.imageshack.us/img62/568...8444ww4.th.jpg
http://img77.imageshack.us/img77/982...8445wd4.th.jpg
http://img136.imageshack.us/img136/4...8449to3.th.jpg
http://img136.imageshack.us/img136/1...8451ir5.th.jpg
awsome,dude!
Nice build.... and really awesome case for the rotaries...
I'm looking forward to the temps ;)
thanxs guys, symphy i cant wait to see temps at load myself:toast:
http://img141.imageshack.us/img141/7...8458oq8.th.jpg
http://img156.imageshack.us/img156/7...8456xp1.th.jpg
http://img141.imageshack.us/img141/6...8457ac0.th.jpg
Great work mate, congrats on finally firing her up, you've been planning it for a while, tis always good to see ideas come to be. I hope you get the loaded temps you're after :toast:
thanxs man, you have played a big part in my design thanxs.Quote:
Originally Posted by aussie_guy00000
Thats a nice case isnt it, and the drawing was spot on :toast:
I have moved the SLHX from after the HX to before. Static charge after that noinsulation run was 450PSIG :eek: this should help with pull down times
:toast:
Can't wait too see some loaded temps...under -100*c :D
me too, im ordering a E6600 for the occasion :toast:Quote:
Originally Posted by LukeXE
i also need a 25uf cap and high pressure gauge, the 35uf cap one im using is the wrong value and first stage compressor doesnt start will high pressure on the low side. :mad:
for now ill use my Dtt temp probe until the gfroster cascade controller is ready mid october.
systems leak testing for a week or so then its time to insulate and bench
lets see what i can get ;)
Originally Posted by kayl
well done kayl look forward to the test
that e6600 wont no what hit it:D
thanxs bazx, soon as it arrives next week benching time :toast:Quote:
Originally Posted by bazx
http://img154.imageshack.us/img154/1...8493be0.th.jpg
http://img90.imageshack.us/img90/495...8494jq0.th.jpg
looking good :toast:
what about temps?
thanks
[QUOTE=LittleDevil]looking good :toast:
its in the -8x's at the moment load with the preseler, -97c idle.
i think i need to shorten second stage capillary line.
that damb cold bug at -50c is a pain, each restart i have to let it warm up, same with a crash, it sucks.
http://img511.imageshack.us/img511/2...8499fb5.th.jpg
http://img511.imageshack.us/img511/9...8501ez3.th.jpg
http://img511.imageshack.us/img511/9...8500nh3.th.jpg
:cussing: bad news my E6600 got lost in the mail.
It was ment to arrive monday, i spoke with delivery centre and they had it as being delivered monday but i never got it, have to wait till next moday before sender can place a claim through australia post damit.
so looks like the E6600 benching is on hold till then, not sure how long they will take to sort either:(
looks like im gonna have to work on the cascade instead, thinking of removing the SLHX from second stage to try and improve temps.
:mad: That is annoying! I hate it when that sort of thing happens.
Hope it's not just a bs stalling tactic, good idea to check WHERE it was delivered to on Monday.
Wonder if the Conroe will have the same cold bug?
Originally Posted by Nephilim
id say im gonna have to wait a few weeks for the claim to go through australia post. i hope the conroes doesnt have the cold bug, other wise its gonna be a :banana::banana::banana::banana::banana: with the gfroster to turn second stage on and off. :mad:
removed the SLHX and charged her again, much better now, i have cold return to the compressor at load which is what i like to see :toast:
http://img206.imageshack.us/img206/1982/108lg6.th.jpg
http://img82.imageshack.us/img82/2507/93ur4.th.jpg
-93°c @ what load?
thanks
that resistor load was 160w, but its a little more than that as uninsulated.Quote:
Originally Posted by LittleDevil
that sort of load temp was what i was aiming for;)
-102c idle
32m run -96c.
45mins dual prime -90c.
about 2psig low side pressuare load, just vacuum idle
http://img64.imageshack.us/img64/574...8576mf6.th.jpg
http://img64.imageshack.us/img64/995...8581px7.th.jpg
very impressive numbers kayl
And first stage @ loaded temps?
thanks
thaNXS BazxQuote:
the first pic shows first stge at load, -38c out with r290:toast:Quote:
cascade also does -97c with 160w resistor load :toast:
k, with the Asus P5B once die temps hit 0 it goes 256. (-1)
so idle 169=-87c and load 183c=-73 die temps.
1mb spi run with 25sec.
http://img144.imageshack.us/img144/5...diesno7.th.jpg
3dmark 2001 -102c idle and -97c max load
http://img156.imageshack.us/img156/5...8634te2.th.jpg
http://img169.imageshack.us/img169/5...8631jn3.th.jpg
http://img169.imageshack.us/img169/5...8632ie3.th.jpg
http://img144.imageshack.us/img144/6...132kxz9.th.jpg
Nephilim came around tonight with his E6400 and show me some stuff in bios :toast:
little ram timming changes never have though of;)
with my e6600 i had fsb limit at 458, same with a 8x and a 7x.
the E6400 fsb limit was also 458, but with some ram changesclocked fine to 535 4-4-4-11
we ran out of time as was working on his unit as well.
we manged E6400 at 4.3mhz dual prime 3mins about 100mhz off WR
cascade sat at -102 most of the time doing spi runs.
32m 13m 48.625sec 4195MHZ E6400 4-4-4-11 Dan/Kayl team cascade -100c
http://img130.imageshack.us/img130/1...pi1mjo7.th.jpg
http://img66.imageshack.us/img66/133...8secnv1.th.jpg
http://img110.imageshack.us/img110/7...minsbz4.th.jpg
http://img165.imageshack.us/img165/6...8777bz3.th.jpg
http://img165.imageshack.us/img165/4...8775do3.th.jpg
just some 920D dual core action before i send and do last little bits.
5ghz at 1.7v bios
1hr orthus -92c.
-98c 3dmark01 runs.
http://img370.imageshack.us/img370/1...9157ho8.th.jpg
http://img376.imageshack.us/img376/2...9158fu8.th.jpg
http://img376.imageshack.us/img376/7...9160jo1.th.jpg
http://img299.imageshack.us/img299/2...9162wm8.th.jpg
http://img155.imageshack.us/img155/4...9164nn4.th.jpg
