what makes everyone think conroe is faster.
maybe at stock yes but with merom having the same core and a far lower wattage maybe it will fly like mobiles usually do.
anyway until both are actually out how do we know which is in fact faster silicon?
The Merom will prolly be limited to the low fsb.
merom has two things going for it: high multipliers and possibly a better overclock due to low-voltage binning.Quote:
Originally Posted by flytek
conroe will have all the good motherboards, binned for higher clocks, and able to take high fsb due to the better chipsets, motherboards, and socket that they use
I think conroe will be the overall winner even though the merom chips themselves might be better.
nice
Conroe and Merom are the exact same, it will make no sense to make a Merom on desktop board since Conroe is already the exact same thing. Also, as you said before, the only possible difference is that Meroms will be binned for lower power consumption, but the flipside is that Conroes will be getting the higer clocking cores. If you want a Merom on a desktop just undervolt and underclock your Conroe. Overclocking will be interesting though since the FSB is already so high. Obviously the best for overclocking will be the XE for the unlocked multipliers. After that I just don't know, seems very likely FSB will limit you before the chip does. The 800mhz Conroes might help, but they are only 2MB cache which will negate and extra mhz. Seems like overclockers will almost be forced to buy the expensive chips for the high multipliers.
merom is supposed to move to higher fsb in '07 so i don't think they will have fsb limit.
also binning merom for 35watts and conroe for 65watts may lead to merom actually having all the best silicon.
intel also officially supports desktop mobile platform which will be the preference for business users who can save electricity running merom and using less aircon.
add that to the higher multiplier which may make it a lot easier to get decent clocks from a cpu without killing the chipsets and we may be in for a pleasant merom suprise
the jury is still out imo.
Ops
nice job:banana:
Nice news Hicookie :D
Hope it will not have any FSB problem with the merom :p:
I wouldn't call a $316 chip that is faster than the fastest current AMD X2 expensive . . .Quote:
Originally Posted by BrownTown
I believe he was reffering to the XE models (unlocked Multi) which are >1,000$. I call that expensive too.
The current XE models, maybe conroe xe will be cheaper?
i thought i read somewhere that the XE conroes will be even more expensive (1,100-1,200)!! probably outrageous but they always like to charge high for those XE models! Either way, I can't wait to burn this crap s478 2.8e chip i have atm and get a conroe.
it already runs on aopenQuote:
Originally Posted by over@locker886
I thought I would try to test a Merom T7400 in my Asus N4L-VM DH before I tore into my iMac or Mac mini. I flashed the BIOS to the most recent version available on Asus' site (4/28/06 0402) and tried to boot up but I get the following;
AMI BIOS
Intel CPU uCode Loading Error
Unknown BIOS Error. Error Code = FBDF
Press F1 to Resume
It was working fine with the my Yonah T2400 in place. I can't get the F1 key to register in order to resume. Perhaps I need a beta BIOS from Asus? I was under the impression that Merom would work in this board with the latest BIOS. Thanks in advance for any help.
I also have the Merom 2.16 GHz and the N4L-VM motherboard, with no luck. I am having the same issue as Macaholic, above. The first post says USB works, and when I connect a USB keyboard, the POST screen does get past, but I can't enter the BIOS or anything still.
Any clues?
hicookie also used 3.15.06 bios if that helpsQuote:
Originally Posted by hicookie
Is that the 0303 BIOS? The initial release? Because I tried that one as well.
