nice result. Celdar mill have a good potencial of oc
yeah mine does 5Ghz+ on highend air and 5,2 on water.. temp issue
my 631 with 7000 b-cu 5100 s-pi 1 m
5340 s-pi liquid cooled h2o temp 10°C...
incoming L2 on chipset...
what is the best bios for high fsb on p5wd2-e? ;)
NICE~ O/C:toast:
ram speed & timings is good:up:
my 641@ DI Cooling
http://www.xtremesystems.org/forums/...ad.php?t=94068
Let me quote Dj... what's the best bios for this m/b to reach higher fsb? cause we've got to put the chipset under LN2....Quote:
Originally Posted by Dj Rudy
Let us know please...cause this 631 has still a lot to give ;)
Marco
Nice OC... Amazing results...:banana:
Top stuff Dj Rudy! Congrats :toast:
I take it the mods on the board are a 'must have' then. Best get some mods to my P5WD2-E when I get one.
Congratulations DJ;) :clap:
Very nice 631 you've got there DJ...and it's awsome seeing how well most of these Cedar Mills OC. I've got a 560es that does 5GHz+ on ss...but with so many cedar mill's hitting 5GHz on air cooling I might have to swap out the 560es sooner than I thought...wonder what a decent 631 would do with a ss that holds an evap temp of -40c under a 250W load...or if it'd cold bug at those temps...hmm...
if i buy a Cedar Mill Proc would it be a .65nm cpu... or a .90nm cpu...?
if yes i could get this http://www.tigerdirect.ca/applicatio...058&CatId=1978
P4 641 Cedar Mill 3.2 Ghz
or 70$ more a 651 Cedar Mill
http://www.tigerdirect.ca/applicatio...060&CatId=1978
Keep Trying...:DQuote:
Originally Posted by |RickY|
nice clock..
An other ceder mill going that high.
Awesome chips
congrats on your OC
I wonder how much CPU will keep up with AIR-cooling?
For example some cooler like Zalman 9500 or Thermaltake BT.
DJ Rudy
Plese make some test on air cooling. Very interesting.
Thanks.
Originally Posted by Indulgator
he did somethin last night..now it is his daily cpu... he told me he use it @ 4.9ghz ... with a zalman 7000cu on it ;)
Marco
prinsipino1984
4.9 Ggz this is very cool.
Is this CPU C1-stepp?
