Originally Posted by M.Beier
AWESOME WORK :)
Kayl, autocascade, thats 2x compressor's, right?
Peter, Im stunned by this unit, its just AWESOME!!!
One thing I wonder though, rotary, do they make alot of noise?? - That huge fan must, but, wouldnt it be possible to mount 4x 12mm's instead???
How much is there to gain with r402, 5-10 deg loaded, right??? But idle, will it be higher, colder or about the same??
And one more =)
Is there any chance of another condenser so it can fit into a normal width case like mach II / vapoLS just with a biiiit higher case so it ends up with being a 2*midi tower setup ? :)
EDIT:
Peter, I just have to catch you on MSN :p:
